Old 02-05-2008   #1 (permalink)
Phil
View Phil's Photo Album
Default Can I fit a power shower to this system??
Good mornings,
I'm in the middle of quoting my first Power Shower, the customer has his heart set on a Mira Event XS Thermostatic to replace the old thermo mixer unit.
Its a bungalow, dedicated tank feed hot/cold (proven), good pressure, hot water cylinder and cold water storage cylinder of the correct size (downloaded the instructions), the HTSC is in the next room across the hall from the bathroom, I haven't seen the pipe configuration around the top of the HWSC yet but I'll have a look when I'm there tomorrow.
Basically I've never fitted a power shower before but I've spent the morning researching the installation and as far as I know this shower should work fine, but is there anything I need to be aware of, or anything else I've missed.
Phil is offline   Reply With Quote
Old 02-05-2008   #2 (permalink)
ajs heating
Posts: n/a
Default Re: Can I fit a power shower to this system??
don't forget your 3 amp fused spur. needed for shower.
Old 03-05-2008   #3 (permalink)
Phil
Yep I've accounted for that, to spur off an existing ring main for power shower I need part P - yes??
Old 03-05-2008   #4 (permalink)
uug197h
View uug197h's Photo Album
yes you need part P, do you have part p? if you get stuck let me know and i will come over one evening
Plumbing Forum Moderator
Old 04-05-2008   #5 (permalink)
Phil
Cheers Uug- much appreciated,
I had a look in the airing cupboard and the cold supply from the cold water storage cistern in the loft to the shower is installed in the correct way as per the instructions (to avoid airlock) but its in 15mm.
The hot is 22mm from the copper cylinder to the shower and does not have a surrey flange/fitting.
Should these both be in 22mm for a power shower?, the customer was more than happy with the pressure/temp from the old shower (when it was working!) the old shower was thermoatatic mixer.
Also the pump in a power shower, is it like a central heating pump - an impeller (which moves water around rather than pumps) or does it physically 'suck' water from the tank like a straw??
Thanks for any replys
Old 04-05-2008   #6 (permalink)
uug197h
have a look at this site see if it helps
A Guide To Shower Installation From Triton
Old 04-05-2008   #7 (permalink)
Phil
Thanks uug
Old 04-07-2008   #8 (permalink)
Unregistered
Posts: n/a
View Unregistered's Photo Album
Post All about tadalis
Get cialis. seek tadalafil. Where can I buy cialis get tadalafil online without prescrption?
Which Power Flush? Big_joe Central Heating Forum 2 10-04-2008 11:01 AM
Potterton Proforma flashing green power led ? JackP Central Heating Forum 3 09-03-2008 08:16 PM
External Links: Car Loan : Pio Baroja : Car Finance : Car Finance : Jordan Apparel
Electrical Help
Tiling News
Tiling NVQ
Tilers Tools
Tiling Network
Electricians Forum
Conservatories UK
Tile Forum
Search Engine Optimisation
Tile Pages
