Old 29-04-2008   #1 (permalink)
rdo1104
View rdo1104's Photo Album
Unhappy Hot Water Pressure to bath & Showers
My system is gravity fed and everything is in the loft (headers, cylinder etc.) I have just had a new 22mm feed fed to my new bath, a 22mm feed fed towards my first shower which reduces to 15mm prior to a salamander 1.5 bar pump, the 15mm pipes are then split to feed a second salamander 1.5 bar pump for shower 2.
Since having an upgrade to 22mm towards the showers the pressure flow in shower 1 is worse than before and temperature fluctuates which has never happened before. (Problem 1)
Problem 2 is that due to the tap in the new bathroom being a 15mm inlet fed ceramic disc type (not sure what I'm on about here but am quoting information from another source) this needs to be pressure fed.
So to summarise, what is the best approach if I started from scratch to feed 2 showers (negative head) and increase the pressure to the bath. It is not an option to change the tap at present so need to conside what pump options I have and if I need a Surrey Flange or similar fitting.
I know this is a long topic but hopefully we can break it down into stages. This is seriously beginning to damage my health
Thanks in advance - Rhys
rdo1104 is offline   Reply With Quote
Old 29-04-2008   #2 (permalink)
ajs heating
Default Re: Hot Water Pressure to bath & Showers
why on earth are you running two pumps ?
and 22mm feeds reduced to 15mm supplying two pumps. not enough if you run both pumps at same time.
the way your going would be easyer to have an salamander esp pump that will supply the lot.
ajs heating is offline   Reply With Quote
Old 30-04-2008   #3 (permalink)
rdo1104
Cheers AJS - I was beginning to think that a single larger pressure pump is the way to go so would I be looking at a 3bar pump? and is it always necessary to fit a flange (surrey or Essex).
Second problem is the supply to the bath due to the type of tap which also needs a pump - do you have a view on which pump to go for and would this need a separate flange?
Many thanks
Rhys
Old 30-04-2008   #4 (permalink)
ajs heating
have a look at the salamander pump site. give you some ideas.
i would use a esp pump to supply the whole lot.
use a surry flange or essex flange take the supply to pump inlet and pump outlet feeds showers, taps, baths etc
Old 02-05-2008   #5 (permalink)
rdo1104
cheers AJS
low pressure from hot water cylinder atakd Plumbing Forum 6 19-06-2008 10:27 AM
: How can you increase the Water Pressure ? neco Plumbing Forum 7 06-06-2008 06:09 PM
Hot water pressure low after installign shower Unregistered Plumbing Forum 0 28-01-2008 05:38 PM
Open Question: Water from my sink is ending up in my bath, can you help? RSS Feeder Plumbing Questions 0 10-01-2008 09:32 PM
How can you increase the Water Pressure ? nylees Plumbing Forum 0 28-11-2007 12:37 PM
External Links: Debt Consolidation : Refinance : Unblock Sites : Submit article : Download movies
Electrical Help
Tiling News
Tiling NVQ
Tilers Tools
Tiling Network
Electricians Forum
Conservatories UK
Tile Forum
Search Engine Optimisation
Tile Pages
