Results 1 to 12 of 21
Plumbing & Plumbers Forum - Condensation in the loof space (water tank) Condensation in a loft space. My Daught
Like Tree7Likes
Discuss Condensation in the loof space (water tank) Condensation in a loft space. My Daught at UK Plumbers Forums; Condensation in a loft space. My Daughter rang me in a panic this evening....dad the house roof is leaking... Turns out her husband was in the loft getting the Xmas ...
    Dec 2009
    33
    Default Condensation in the loof space (water tank) Condensation in a loft space. My Daught
    Turns out her husband was in the loft getting the Xmas decoration down and was horrified to see water over the boxes he put up there a few weeks ago when they moved in....not long married and there first house,
    I spoke to him on the phone....there seems to be water everywhere...we must need a new roof...what are we going to do...
    I ask...are you sure its not Condensation...no he replies...can you come quickly and have a look...what should we do,
    Anyway we drive over I climb up the loft access ladder...and see black felt type stuff under the roof tiles with lots of water droplets on it,
    Looks like condensation to me I say...then I spot 2 big plastic water tanks one with a lid on the other without,
    Where is the lid off that one I ask....oh there it is he says the plumber we had out the other week may have left it off...he was up here doing something,
    Anyway as best we can we refit the lid...they don't fit that well on either,
    So is Condensation in the loft space a problem in modern houses with tiled roofs....the loft decking has around 6" of insulation down so I expect it get quite cold up there....
    I wonder what significance the water tank with its missing lid had on the problem and is there a way to stop the Condensation....I suggested they leave the trap down open for a few days to get some heat up there and look again to see if the water on the underside of the felt has gone,
    The main body of the 2 big plastic water tanks have fibreglass insulation around them...the sort that immersion tanks used to have....but the lids are unlagged.....should the lids be lagged if so what with....the water tanks are circular about 30" dia.
    Nick.
    Simon F's Avatar
    Nottingham
    2,211
    Default Re: Condensation in the loof space (water tank) Condensation in a loft space. My Da
    over time if the timber is always wet it will rot!
    monitor the situation and see if it improves with the lid back on, it could be the tank is getting hot due to water pumping over, hot water creates steam. so that could need checking.
    Plumbers Arms member MrMeek's Avatar
    Aug 2012
    County Durham
    259
    its just condensation of the tank having no lid, fit the lid and it should have a jacket around the whole thing and on top, plumbing merchants do them cheap as chips aswell
    Norfolk
    3,000
    Yes the storage cisterns should have lids and insulation to meet water regs. I do not believe this is the cause of condensation though. It sounds like there are inadequate ventiltation. Have you got sofit vents or any other ventilation openings within the roof space? This is an enclosed space so ventilation is extremely important to prevent long term issues.
    tweakyboy's Avatar
    Jun 2010
    Bristol
    472
    If I were you I would close the loft hatch, the warm air from the house will go into the roof space and condensate on the cold felt. Especially now the weather is heading to the minus figures. See how you get on with the lid on, if not you could try adding some soffit vents around the house.
    IMPORTANT:Carbon Monoxide can be produced when ANY fuel is burnt, including oil, gas, wood and coal.
    Member petercj's Avatar
    Jun 2012
    1,448
    Check to see if the loft insulation has been laid in a way that is blocking air flow.
    ******************** http://www.comodo.com/home/browsers-...rs/browser.php ********************
    lame plumber's Avatar
    Nov 2012
    North Devon by the sea
    15,667
    chech the f & E tank isnt pumping over, that causes massive condensation issues, plus storage tanks need insulation as per regs and finally roof space needs vents to circulate cool air through as its a cold roof set up. probably at least 2 of the previous issues apply here
    www.jcdheating.co.uk
    Guest123
    Condensation is caused by poor ventilation. There should be roof tile vents on your roof allowing air to freely circulate throughout the roof and attic space. There should also be smaller circular vents at the eaves and sometimes these small vents get blocked by the attic insulation. In the meantime, get a dehumidifier up there until the ventilation is sorted out.
    Both water tanks should be jacketed and have what is known as a bye law 30 kit. This kit contains a small breather vent for your tank lids which are fixed and sealed to the tank. Bye law kits are available from Screwfix and only cost about £5.
    Cold Water Storage Tank Byelaw 30 Kit | Screwfix.com
    Jun 2012
    1,448
    On the pumping over suggestion - I had this problem some years ago, and discovered that some muppet had fitted the central heating pump the wrong way round, i.e. pumping in the wrong direction, which was producing pumping over, and steam in the loft had soaked everything.
    Another possibility is that if the loft insulation has been taken right up under the eaves, and there are soffit vents fitted, the air flow may have been blocked.
    If there are no vents fitted, it could be that breathable roof felt has been used, which has been known to cause problems sometimes. If that is the case, the remedy will be to fit soffit vents, and maybe an air-brick or similar vent.
    Nov 2012
    15,667
    forget a dehumidifier in a roof space, thats like trying get rid of fog in your garden with one, a waste of time, just vent and go
    erpkid's Avatar
    Nov 2012
    Steeple Bumpstead
    928
    Quote Originally Posted by lame plumber View Post
    Yes venting is the answer including tile vents . We use a local roofer to install lots of these and it usually solves the problem. Lifestyle too makes demands as this is the time of year when dry towels on rads and have the windows closed. Windows that due to modern glazing and sealing are very good at keeping heat and moisture in. A hard balance to strike I am afraid. In our very drafty older property we have none of these problems but need smelling salts when the heating bill comes in.
    lame plumber likes this.
    We make a living by what we get, we make a life by what we give.
    -Winston Churchill
    Nov 2012
    15,667
    good old edf have just put my dd up fm£100 to £140 a month, checked their figures and they are within a pound or two totally correct. Tried turning off the Aga but the wife and dogs went for me!!!!!!!!!!
  1. loft space cylinder and joist loading
    By jimk280 in forum Plumbing Forum
    Last Post: 13-05-2012, 09:11 AM
  2. Heating and hot water pipes condensation challenge
    By Robinwelch1000 in forum Central Heating Forum
    Last Post: 05-05-2012, 11:51 PM
  3. Replies: 2
    Last Post: 28-02-2012, 05:49 PM
  4. Plastic Pipe in loft space for power shower
    By MickBrown in forum Bathrooms, Showers and Wetrooms
    Last Post: 28-02-2011, 02:07 AM
  5. Condensation or leak on main cold water pipe
    By Jez974 in forum Plumbing Forum
    Last Post: 08-02-2011, 05:04 PM
  6. soil pipe vents into loft space - advice please?
    By vdubowner in forum Sanitary Ware
    Last Post: 24-05-2010, 08:08 PM
  7. no hot water / space heating
    By nysk2008 in forum Central Heating Forum
    Last Post: 18-04-2010, 05:46 PM
  8. no hot water gloworm space saver 50
    By julie in forum Central Heating Forum
    Last Post: 11-10-2009, 05:47 PM
  9. unvented cylinder in loft space
    By sasik in forum Plumbing Forum
    Last Post: 19-02-2009, 11:52 AM
cold water tank condensation
how to stop condensation on cold water tank
condensation in cold water tank
condensation cold water storage tank
