Results 1 to 12 of 12
Plumbing & Plumbers Forum - Wall hung basins?????
Discuss Wall hung basins????? in the Plumbing Forum at Plumbers Forums; Hello guy's, am just looking for a bit of advice, when you guy's fix in a wall hung basin and the wall is made out of plaster board, do you ...-
14-08-2009 #1Plumbers Arms member
- Jun 2009
- Hampton court, Surrey
- 1,601
- Thanked 42 Times in 42 Posts
Hello guy's, am just looking for a bit of advice, when you guy's fix in a wall hung basin and the wall is made out of plaster board, do you just fix brackets onto the plasterboard or do you cut out the board and put in some ply and a nugging?
Also if you were fitting a shower and the wall is made out of plasterboard, do you cut the plasterboard out and put plywood in and just get a tiler to tile?
Or do most of you guy's actually do the tiling your selves?
I look forward to your advice
Regards
Mutley
14-08-2009 #2Plumbers Arms member
- May 2009
- 7,303
- 218
Re: Wall hung basins?????
A wall hung basin will require a battening behind fixed between the joists if put on plaster board wall, any other way it will become loose, fall off
Shower walls should be marine ply, plasterboard will cause trouble not just because it is like a sponge but also to mush movement and when some one used shower every day, leaning and banging against wall the tiles will blow
Make sure all pvc’ed well before tiling, I tile myself, find it very satisfying but know other plumbers who get tilers or others in
If repairing leaking shower were bottom tiles loose and walls plaster board if customer will not go for complete re do always cut out bottom section of shower wall and fit marine ply to fit behind bottom layer of newly fixed tiles
When grouting shower areas, make sure you use the correct grout and that it is pushed well into the joints
14-08-2009 #3Super Plumbing Forum Contributor
- Feb 2009
- Liverpool
- 1,972
Easy answer: Yes!
The number of fittings I have seen coming away because of bad fixing is tremendous.
One of the worst is PVC soil pipe. Play spot the expansion anchor point some time.Last edited by Bernie2; 14-08-2009 at 11:16 AM.
14-08-2009 #4Plumbing Forum Contributor
- Jul 2009
- iom
- 55
depends on the width of the studs,if you have a small basin that ends up between them you cant unless the customer is happy with you chopping half the wall out.in this case i use decent wall anchors and some silicone behind the sink,when it cures the sink will not be going anywhere.
another tip if you have time is to brush the wall behind the sink with pva and let it set
14-08-2009 #5Plumbers Arms member
- May 2009
- 7,303
- 218
You may think you are siliconing basin to wall,but infact what you are doing is siliconing basin to paint and the surface paper of the plaster board,a bit of leaning and it will tear/pull off
Then any making good of the wall is down to you to make good,when a battern is fitted as should have beenLast edited by Puddle; 14-08-2009 at 12:48 PM.
14-08-2009 #6Plumbing Forum Contributor
- Jul 2009
- iom
- 55
but if you brush the plasterboard with pva it sucks it in and sets,not ideal i know but if the customer does not want the cost of ripping the wall apart you can not do it
14-08-2009 #7BeelineGuest
Plaster can not hold weight such as a wall hung sink with silicone or using "special" fixings. Bad reputation from a cut corner will far outweight the little extra work to do it right and use a batten behind.
Years ago my old boss had a subbie tiler, so useless we had to fix the battons for him before he came to tile! Do your own if you can learn, you can give a customer what you promise that way.
If the plasterboard is a stud wall, i would use marine grade ply if you can find it, or normal ply and 2 or 3 thick coats of PVA. If its dot and dabbed to a solid wall i usually just tile straight to it.
Just my two cents worth, good luck.
14-08-2009 #8Plumbers Arms member
- May 2009
- 7,303
- 218
Well I think that 2 cents worth is worth a dollar Belline
14-08-2009 #9Plumbing Forum Contributor
- Jul 2009
- iom
- 55
its the customers choice not mine,it was a very small basin 9/10".
bad reputation and cutting corners comments are uncalled for
the sink had to be fitted between the studs,customer choice,and the basin aint going no where
14-08-2009 #10Plumbers Arms member
- Jun 2009
- 1,601
hey, thanks guys. Great to hear all your techniques.
Could you please tell me where you attach the bolt to? As in, do you have to drill it just to the back of the noggin you made between the studs? or right through the back of the plasterboard on the other side of the wall?
Am sure my last boss did it that way!
14-08-2009 #11Plumbing Forum Contributor
- Jul 2009
- iom
- 55
15-08-2009 #12Steady Plumbing Forum Contributor
- Apr 2009
- N. Devon
- 286
- Thanked 7 Times in 7 Posts
justr put noggins in the wall and use the fisher fixing kits, very easy this way
bath coming away from wall
By tonell31 in forum Sanitary WareReplies: 5Last Post: 05-08-2009, 02:17 PM -
broken pipe stuck in wall
By moggs160 in forum Plumbing ForumReplies: 3Last Post: 16-03-2009, 07:39 AM -
Help-hiding wastes on wall hung sanitory ware
By lla in forum Plumbing ForumReplies: 2Last Post: 06-03-2009, 04:43 PM -
Problem fitting wall hung toilet pan on frame
By spencergate in forum Sanitary WareReplies: 0Last Post: 05-02-2009, 07:02 AM
Mixer shower & solid brick wall
33 Minutes Ago in Bathrooms, Showers and Wetrooms
