Chatrooms
Hints & Tips - Plumbing Forum | Free Plumbing Advice
Notices
Old 18-08-2009   #41 (permalink)
imranhafeez
Info
Default Re: Hints & Tips
i like the tips they realy worked for me
keep em coming
imranhafeez is offline
Old 18-08-2009   #42 (permalink)
ipeaquint
Info
Plousane.... What do the French use in place of Fairy Liquid?
ipeaquint is offline
Old 18-08-2009   #43 (permalink)
Plouasne
Info
Quote:
I have never seen it used in plumbing, 99.5% heating systems are closed circuit, filled by the mains, or via a force pump if anti gell (anti freeze) is used
otherwise its liquide lavage, which can come in concentrated form in sachets to make 1 litre of liquid
Have you ever made this up, to help "drag round" a gravity circulation cuircuit
http://i108.photobucket.com/albums/n...Venturitee.jpg
Plouasne is offline
Old 18-08-2009   #44 (permalink)
Bernie2
Info
Its called an injector tee over here.
Bernie2 is offline
Old 18-08-2009   #45 (permalink)
Plouasne
Info
Quote:
But have you ever made one up??, I have and in the UK as well, I have heard that they cost 25 notes to buy one, in the UK now, when you could make one for about a fiver
Plouasne is offline
Old 01-09-2009   #46 (permalink)
Plouasne
Info
Default Re: Hints & Tips, Simple pressure test kit, how to make it
An easy way to make an air pressure test kit, all that is needed, is
1) Old car tyre schrader valve
2) A short of 8mm copper tube
3) An 8mm x 15mm reducer
4) Car foot pump with a pressure gauge on it
Remove the inner part of the valve, clean the outside of the valve body, slide it into the 8mm copper tube, solder the valve body, into the 8mm copper tube, and the tube into the 8mm x 15mm reducer, when cold refit the inner valve body
There's your home made test kit, suitable for air testing just about any pipework, after first fixing
Plouasne is offline
Old 01-09-2009   #47 (permalink)
cletus
Info
if you can never find your flux brush,or it is stuck in a pot of flux which always seems to end up all over your tools when you move from job to job ,try this-cut a bit of 22mm copper a bit longer than your brush,solder 22mm cap end onto one end .shove your brush inside(wipe it first),push fit cap end (removable!)on other end-that is it!!chuck it in your tool bag and you always know where it is when you next need it.
cletus is offline
Old 18-11-2009   #48 (permalink)
heinz57
Info
Drilling into floor tile? Prevent your tile bit from drying out by moulding a small handful of Plumbers mate into a string about 4 inches long. Start drilling for about 2 seconds so you have your bullseye, now mould the Plumbers mate string piece into a circle around where your drill bullseye is. Press down firmly to get rid of airholes, now fill with 4mm of water and hey presto you can drill your hole without the expensive drill bit burning out!
heinz57 is offline
Old 18-11-2009   #49 (permalink)
tackleburger
Info
Quote:
Originally Posted by azzvon12 View Post
When changing a washer on bath or basin taps i always carry a small plank of wood in the van.Drill two holes the width of the taps,slide the wood over the spouts of both the taps,this usally stops the taps spinning and gives a better purchase when trying to unscrew the insert to get to washer that someone seems to have cemented in place.Think ive explained that right.
Nice one mate turns it into a deck mixer if you like.
Quote:
Cracker!
Last edited by tackleburger; 18-11-2009 at 07:38 PM. Reason: Automerged Doublepost
tackleburger is offline
Old 18-11-2009   #50 (permalink)
alexclark
Info
Quote:
loving this :-p
alexclark is offline
Can you suggest a new forum category? Dan Links, Forum Updates, News and Site Suggestions 38 25-11-2009 10:01 AM
Open Question: Which are the most important plumbing safety tips? RSS Feeder Plumbing Questions 0 04-06-2009 03:03 PM
