Re: Hints & Tips
One I taught myself ... easy way to make two level marks on the wall ...
When measuring for two holes to be drilled (e.g. radiator, curtain rail, picture or whatever), place two pencil marks on your spirit level at required distance apart. For example, when two holes 435mm apart, draw two pencil lines 435 apart on your spirit level.
Measure and mark first hole on wall, then put one mark of spirit level on this. Tilt spirit level until level and mark second hole on wall from your spirit level mark. Voila!
Also - although most people will know this one - when drilling holes use a tiny drill bit first then increase in size as necessary. And when drilling through tiles, drill slowly with a tile drill bit.
