Results 1 to 4 of 4
Plumbing & Plumbers Forum - Balancing Radiators
Balancing Radiators
Discuss Balancing Radiators in the Plumbing Forum at Plumbers Forums; Hi, wondered if anybody can help. I need to balance about 6 radiators in a ground floor flat as they are all cold at the bottom. The bathroom one was ...
    Plumbing Forum Contributor
    Jul 2012
    30
    Default Balancing Radiators
    I need to balance about 6 radiators in a ground floor flat as they are all cold at the bottom. The bathroom one was stone cold and I found the TRV pin was stuck. This was released and it was burning hot....however since then all the rads are stone cold now?
    The last radiator (nearest the front door) does not have a TRV by the way!
    Whats the best way to do this?
    7,206
    Default Re: Balancing Radiators
    Sounds more like a circulation problem than a balancing one. I'd be checking pump and rad valves.
  3. If You Burn It, It Can Kill You.
    east london
    6,666
    if nothing is hot its not a balancing problem
    Feb 2009
    Liverpool
    1,972
    Overhaul all the valves, if one pin was stuck why should not all the rest be?
  1. balancing
    By stecorcoran83 in forum Central Heating Forum
    Last Post: 17-01-2011, 09:39 PM
  2. Replies: 14
    Last Post: 08-12-2010, 07:12 PM
  3. Does anyone know anything about balancing radiators?
    By baird83 in forum Central Heating Forum
    Last Post: 24-11-2010, 07:29 PM
  4. Balancing radiators
    By a9blue in forum Central Heating Forum
    Last Post: 20-02-2010, 06:53 PM
balancing radiators
balancing radiators forumhow to balance radiatorsradiator balancingbalance radiators in flatquick way to balance radiatorsradiators balance
