Results 1 to 8 of 8
Plumbing & Plumbers Forum - Bath pop-up waste
Bath pop-up waste
Discuss Bath pop-up waste in the Plumbing Forum at Plumbers Forums; Hello I'm fitting one of these fancy cable operated pop-up wastes on a new bath install. Due to lack of space under bath and need for 75mm trap depth (waste ...
    Jul 2012
    Default Bath pop-up waste
    Hello
    I'm fitting one of these fancy cable operated pop-up wastes on a new bath install. Due to lack of space under bath and need for 75mm trap depth (waste runs to soil stack),the trap water level will be just below the bottom of the bath.This means that the pop-up mechanism will be permanently submerged.Any likely probs? I live in a hard water area.
    Don
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,252
    Default Re: Bath pop-up waste
    make sure its stainless steel or at least all brass including cable.
    a replacement is between £18-30 and will nark you off replacing it each year or two.
    cant you chop down floor board and lower stack boss?
  3. ¡ƃuıɥʇou ʍouʞ ı˙˙˙ɹǝqɯǝɯǝɹ puɐ
    ¿ʞɹoʍ sɐƃ
    Jul 2012
    Don[/QUOTE]
    Hi Redsaw
    Mod you suggest not practical. The stack is "nextdoor" in an airing cupboard. Access awful.
    Don
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,252
    use a 'bendy' 40mm pipe connector
    ¿ʞɹoʍ sɐƃ
    Jul 2012
    I think i'll take the Pop up back and swop for a Click clack type which won't mind staying wet.
    Don
    Apr 2008
    West Yorkshire
    2,051
    Click clack are annoying on baths as you keep operating the thing by accident.
    mountainman's Avatar
    Jan 2012
    Essex
    3,317
    Default
    Raise the bath??
    stratobuddy
    What's wrong with an old-fashioned bath plug, nothing to go faulty except the plug itself, then get a new one for 50P from any hardware shop?
    PS I just bought a new plug and fitted it myself, I didn't even need to call in a plumber!
  1. Bath waste
    By leslie50 in forum Plumbing Forum
    Last Post: 19-04-2011, 07:16 PM
  2. bath and sink waste with toilet waste
    By cardigan in forum Plumbing Forum
    Last Post: 10-03-2011, 09:00 AM
  3. Replies: 7
    Last Post: 11-07-2010, 10:24 PM
  4. Replies: 2
    Last Post: 10-07-2010, 01:35 PM
  5. Bath hole oversize for bath waste
    By Gadabout in forum Plumbing Forum
    Last Post: 16-04-2010, 08:41 PM
pop up waste parts
pop up bath plug mechanism
click clack waste repair
bath pop up waste problems
pop up waste replacement parts
problems with pop up plugs
replacement click up waste
