Results 1 to 6 of 6
Plumbing & Plumbers Forum - booster pump for shower question
Discuss booster pump for shower question in the Plumbing Forum at Plumbers Forums; hi all i need to fit a booster pump for a new shower, however there is no room in the airing cupboard to fit one. customer said he wants one ...-
20-08-2012 #1Steady Plumbing Forum Contributor
- Sep 2008
- portsmouth
- 141
- Thanked 1 Time in 1 Post
customer said he wants one in the loft, i will fit a essex flange on the cylinder coming off with a loop to run into the loft to avoid airlocks .
how would i know what pump he needs for his water pressure. and is it a negative pressure pump needed as it will be pulling water into the loft.
thanks .
also the cold feed will need a 300mm clearance from bottom of cwsc to inlet of pump. so i may need to raise cwsc up to comply with that ..
20-08-2012 #2Plumbers Arms member
- Nov 2010
- Tavistock. Devon
- 1,798
- 38
- Thanked 173 Times in 160 Posts
Re: booster pump for shower question
Are you sure no room in cupboard ? Neg Head pumps very expensive.
20-08-2012 #3Steady Plumbing Forum Contributor
- Sep 2008
- portsmouth
- 141
im sure theres no room got a cylinder in there and above that they got boiler for central heating. no room on floor either cylinder is at the front and no room either side
20-08-2012 #4Plumbers Arms member
- Jun 2012
- London/Kent
- 1,725
- 102
- Thanked 183 Times in 179 Posts
how about fitting it under the end of the bath ???
20-08-2012 #5Steady Plumbing Forum Contributor
- Sep 2008
- portsmouth
- 141
i did look under the bath not much room. airing cupboard is down the hall from bathroom so would have to run under floor then up into pump. more than likely cause air locks .
20-08-2012 #6Plumbers Arms member
- Jun 2012
- London/Kent
- 1,725
- 102
Why don't you have a look at an Aqualisa Quartz or Mira do a similar one they have a built in booster pump.
http://www.aqualisa.co.uk/upload/LIT...inBrochure.pdf Page 45 on wards.
shower booster pump or electric shower?
By calinfila in forum Bathrooms, Showers and WetroomsReplies: 5Last Post: 18-07-2012, 09:44 PM -
Booster pump with digital shower
By Seedler in forum Plumbing ForumReplies: 4Last Post: 02-02-2012, 05:38 PM -
Shower Booster Pump
By classic0904 in forum Bathrooms, Showers and WetroomsReplies: 0Last Post: 18-02-2009, 11:44 AM -
shower booster pump
By kenneth_cohan in forum Bathrooms, Showers and WetroomsReplies: 1Last Post: 07-07-2008, 07:38 PM -
shower booster pump
By kenneth_cohan in forum Bathrooms, Showers and WetroomsReplies: 0Last Post: 07-07-2008, 05:46 PM
1Likes
pipe bender to fit in cordless...
2 Minutes Ago in Plumbing Tools
