Results 1 to 2 of 2
Plumbing & Plumbers Forum - StelFlow unvented indirect cylinder 210L
Discuss StelFlow unvented indirect cylinder 210L in the Plumbing Forum at Plumbers Forums; Hi all, Anybody using these? Any known problems? Thanks, Chris...-
18-08-2012 #1New to Plumbing Forum
- Aug 2012
- 8
Hi all,
Thanks,
Chris
18-08-2012 #2UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,167
- 531
- Thanked 430 Times in 365 Posts
Re: StelFlow unvented indirect cylinder 210L
Yeah, I've fitted a fair few of them.
Have had issues with noise. Mainly caused by the type of expansion vessel they were shipping them with.
I understand they are now using a different type of vessel with a non restricted opening to the vessel.
They sent me one free of charge to an installation I had issues with (as part of their trial) and it solved the problem.
Other than this, I've no major complaints. I do find the posistions on the flow and return and the cold feed a bit odd. In this day and age, we could site them over each other and not off set round the cylinder. Just means its more work to make the pipe work look neat. But then they arent the only manufacturer guilty of this.
Gone fishing!!
Noisy Stelflow [ RM unvented cylinder ]
By mattyp in forum Central Heating ForumReplies: 24Last Post: 03-02-2012, 11:12 PM -
Horizontal Unvented Indirect Hot Water Cylinder that is at least 150 Litres in size
By moley in forum Central Heating ForumReplies: 34Last Post: 04-12-2011, 03:00 PM -
Do I need to inform Building Control of new unvented indirect cylinder?
By Gromit in forum Central Heating ForumReplies: 21Last Post: 30-04-2011, 12:08 PM -
Unvented Indirect Cylinder - wiring on hot pipe - see photo
By Gromit in forum Central Heating ForumReplies: 11Last Post: 22-11-2010, 07:38 PM -
Indirect Unvented Cylinder losing pressure on heating side
By theflame69 in forum Central Heating ForumReplies: 7Last Post: 13-05-2010, 02:53 PM
Best way to remove solder ready...
1 Minute Ago in Fittings & Pipes
