Results 1 to 6 of 6
Plumbing & Plumbers Forum - grundfos#pump number
Like Tree2Likes
  • 1 Post By chris watkins
  • 1 Post By snowhead
Discuss grundfos#pump number in the Plumbing Forum at Plumbers Forums; I'm looking at Grundfos UPS 15-50 pumps on web and I've finding several different numbers for which seems to be identical 5m pumps, numbers I'm finding are 96281442, 96281448, 96281446, ...
    26
    Default grundfos#pump number
    Can someone help explain the differences,
    Super Plumbing Forum Contributor on31ll's Avatar
    Apr 2012
    Mogadishu
    2,057
    Default Re: grundfos#pump number
    Surely the pump if has the same specs then its the same ? Maybe check out the website and see if theres a major design difference which would make you buy one over the other !
  3. IMPORTANT: Carbon Monoxide can be produced when ANY fuel is burnt, including oil, gas, wood and coal.
    Jun 2012
    London/Kent
    1,728
    Have not checked No.s but most likely they will be the same pump head but in different body lengths you can get ups 15/50 that are 130mm or 180mm between the centers you can also get different outlet / connection sizes we tend to use a standard size in this country for domestic CH pumps but abroad & in combi / system boilers you can get 1/2", 3/4" etc.
    Hope this helps, check the full pump spec.
    heliotrope likes this.
    668
    I can find at least 6 numbers for 15-50 130mm all in the range 962814**.
    Some are single trade boxed, some are retail boxed, some are from a trade multipack.
    All are bare pump no valves.
    All are 130mm long with 1 1/2" union size.
    All are 240v
    Can't find any info on Grundfos.
    I've had various numbers before.
    Just buy the cheapest 15-50 130mm you can find.
    The (N) stainless and (B) bronze are more expensive and are not required for heating purposes.
    chris watkins likes this.
    26
    So It's possibly down to how they are sold?
    yes as above the 3 I found all 130,5m 15-50s, very little info from grundfos
    I need 4,running from a manifold, hence trying to keep things consistant.
    New to Plumbing Forum sh7295's Avatar
    Kent
    12
    alot of manufacturers now warranty their products via serial number/ codes and not to receipt or when bought.
  1. Grundfos pump S+F after 6pm Christmas Eve
    By mcnivens in forum Central Heating Forum
    Last Post: 24-12-2011, 07:06 PM
  2. grundfos shower pump
    By barronbathrooms in forum Bathrooms, Showers and Wetrooms
    Last Post: 08-10-2011, 04:24 PM
  3. grundfos pump
    By philtheplumber in forum Plumbing Forum
    Last Post: 09-01-2010, 05:31 PM
  4. Vibration from a Grundfos Pump
    By acoustekltd in forum Central Heating Forum
    Last Post: 09-01-2010, 01:52 PM
grundfos pump serial number
grundfos serial number
Inurl:forum Furniture
hs grundfos pump serial number
grundfos central heating pump body identicalgrundfos pump unions for ups 15-50grundfos ups 15-50 bronzestandard the difference
