Plumbing & Plumbers Forum - Leaky Motorised Valve
Discuss Leaky Motorised Valve in the Plumbing Forum at Plumbers Forums; We have oil-fired CH with 3 motorized valves (for HW, CH and UFCH, downstairs). Recently, I have noticed that the boiler comes on at times when it should not, according ...-
17-08-2012 #1New to Plumbing Forum
- Jan 2012
- 3
We have oil-fired CH with 3 motorized valves (for HW, CH and UFCH, downstairs). Recently, I have noticed that the boiler comes on at times when it should not, according to timers and thermostats. WHen this happens, the valves (ACL Lifestyle) are all in the closed position. THe only way to turn off the boiler is to turn the power off. The problem will last for a day or two and then appear to improve, only to return some days later. The pipe to the underfloor system after the valve to this area appears to get quite warm and the manifold will appear warm (even though the valve is apparently closed).
1. Does this suggest that this particular valve is the problem?
2. Can a valve be a little open and trigger the boiler to fire?
3. WHy does the problem go away from time to time....dodgy switch/dodgy valve?
4. If I replace this old style valve (not a separate actuator and valve), should I bite the bullet and do all 3 valves as the system will have to be drained anyeay?
Many thanks
17-08-2012 #2Plumbers Arms member
- Dec 2011
- Somerset
- 1,826
- 94
- Thanked 185 Times in 180 Posts
Maybe a micro switch in one of the actuators sticking, need to check which has 240v on the orange wire when everything is off.
Read more: http://www.ukplumbersforums.co.uk/pl...#ixzz2AdEwjWbf
17-08-2012 #3UK Plumbersforums Trusted Advisor.
- Apr 2011
- Newcastle Upon tyne
- 6,116
- 306
Re: Leaky Motorised Valve
one of the three is most likely suspect
Motorised valve not turning off
By woodhead666 in forum Central Heating ForumReplies: 3Last Post: 18-11-2011, 07:42 AM -
Motorised valve
By cbrAndy in forum Central Heating ForumReplies: 18Last Post: 01-11-2011, 04:57 PM -
Motorised valve
By plumbingdazman in forum Central Heating ForumReplies: 10Last Post: 09-02-2011, 11:25 PM -
Motorised valve
By slug in forum Plumbing ForumReplies: 9Last Post: 26-09-2010, 09:13 PM -
3 way motorised valve
By tommo in forum Central Heating ForumReplies: 3Last Post: 28-04-2010, 09:33 PM
2 Hours Ago in Plumbing Tools
