Results 1 to 9 of 9
Plumbing & Plumbers Forum - Toolstation basin fixings
Like Tree4Likes
  • 4 Post By system3
Discuss Toolstation basin fixings in the Plumbing Forum at Plumbers Forums; Toolstation > Screws & Fixings > Coach & Roof Bolts > Sanitary Fixing Kit Anyone used these? Half the price of the Fischer version but if thery're anything like the ...
    Apr 2008
    West Yorkshire
    2,033
    Default Toolstation basin fixings
    Anyone used these? Half the price of the Fischer version but if thery're anything like the Bathstore ones the the studs are so blunt they don't even bite into the plugs and just spin round.
    BOD
    BOD is offline
    BOD's Avatar
    Nov 2009
    10,503
    Default Re: Toolstation basin fixings
    used them odd time , but tend to just use sticks like poo , or pink grip
    7,206
    Hadn't noticed them in there. Look the job, I'll have to give them a try.
    Apr 2008
    West Yorkshire
    2,033
    I'm thinking of the half pedestal type basins where the full weight is hanging on these, went to one last month where they failed and the whole thing dropped to the floor ripping the tiles off. Not fitted by me!
    I'm sure System3 was on about using wall anchors but don't they have to pull hard on the ceramic to tighten up?
    system3's Avatar
    Feb 2010
    Alloa, Scotland
    7,066
    Quote Originally Posted by Phil View Post
    I now much prefer wall anchors if it's into a solid wall. You have to pre-tighten them first with a socket wrench so that they expand and grip inside the wall. Here's how:
    Drill a 10mm hole with a SDS drill, insert the wall anchor bolt, leaving enough threads for your basin to slip on to for fixing. Usually 50mm is more than enough.
    Fit the washer and tighten the nut tight to the wall with a socket wrench or adjustable until tight. Slacken off and remove the nut and washer. The bolt is now securely fixed and expanded inside the wall.
    Fit a short plastic sleeve over the threads, slip on basin over bolts, then fit a large rubber tap washer, then a steel penny washer and then the nut over the threaded bolt.
    Tighten bolt until basin is secure, but never overtighten.
    Absolutely solid and never moves and only costs 26p per fixing!
    I use a short cutting of plastic pipe over the threads where it goes through the basin holes to protect the ceramic and a 22mm tap washer with the hole widened and a penny washer behind the nut. Very, very secure and also very cheap to buy a bag of them. A bag of ten only costs £2.59.
    I've also used drop in anchors with a setting tool too with 10mm screwed rod. Fiscsher fixings are way overpriced.
    Here's the ones I use:Toolstation > Screws & Fixings > Steel Anchors > Through Bolt
    petercj, Phil, Plum Bob 66 and 1 others like this.
    Bathroom Design & Installation Specialists.
    Over 34 years experience.
    Rated People 5 Star Rating.
    BY THE WAY I'M NOT COMMERCIAL. A flexible hose, gets up ma nose.
  6. The Following 3 Users Say Thank You to system3 For This Useful Post:
    Dannypipe (12-08-2012),Phil (12-08-2012),steveb (12-08-2012)
    Plumbing Forum Contributor
    Dec 2011
    54
    I do as above and they don't move! I use this with the floating toilets as well.
    Dannypipe's Avatar
    Apr 2009
    Tunbridge Wells
    5,131
    I always use a steel frame for floating toilets and they come with the fixings.
    Gas, LPG, and OFTEC (oil) Registered.... visit my website at: www.prestigeplumbers.co.uk
    Click to follow the link!
    Apr 2008
    West Yorkshire
    2,033
    Regarding the Toolstation sanitary fixings (of which I have a pack in my hand) they don't appear to be as beefy and the Fischer ones and I would trust them on a wall hung basin.
    The M10 wall anchors look the part though.
    May 2010
    1,914
    Normally use fischer fixings but will proberbly give these a go dont look too bad and are a lot cheaper regards turnpin
  1. Replies: 34
    Last Post: 25-07-2012, 09:09 PM
  2. toolstation isolation valves 80p
    By kyle87 in forum Plumbing Forum
    Last Post: 17-02-2012, 12:36 AM
  3. Toolstation
    By bert large in forum Plumbing Tools
    Last Post: 07-01-2012, 09:45 AM
  4. Fixings question
    Last Post: 20-09-2010, 08:54 AM
  5. fixings
    By pauls in forum Fittings & Pipes
    Last Post: 01-12-2009, 10:30 PM
bathstore basin washer
fischer bolts
hanging a basin using pinkgrip
basin fixings
Coach Screws fixing basintoolstation basin fittingfisc italiana screw
