Plumbing & Plumbers Forum - Reducing water pressure (domestic)
Discuss Reducing water pressure (domestic) in the Plumbing Forum at Plumbers Forums; Hello, I am an individual and want to put a question concerning the water system in my own house (in France). I had an Actaris Isobar pressure reducer installed at ...
    Aug 2012
    Default Reducing water pressure (domestic)
    Hello,
    I had an Actaris Isobar pressure reducer installed at the head of the water system by a professional plumber about 4 years ago. The pressure gauge on it reads 2.4 bars and I want to bring it up to 3 bars. For the operation, all taps are closed. I find that 3 complete turns of the adjuster screw (3 x 360°) has no effect on the gauge reading. That surprises me.
    What I now wonder is whether 3 turns on such a device is very little or whether I can already deduce that something is not working properly?
    If anyone here can give me a steer I would be very grateful.
    Thanks in advance
    COS-enFrance
    mountainman's Avatar
    Jan 2012
    Essex
    3,201
    Default
    It's an old valve and gauge and either could be faulty, or maybe your incoming water pressure is only 2.4 bar.
  3. Proud to be 'Part P', the world is now my mollusc!
    Aug 2012
    Default Re: Reducing water pressure (domestic)
    Quote Originally Posted by mountainman View Post
    Thanks, Mountainman for your quick reply. The pressure reading has always been at 2.4 and I know that the incoming water pressure is not always at that level (if it ever is).
    I understand you to mean that 4 years is "old" for a valve or a gauge. Is that right? How often should they be changed, in your opinion?
    Kind regards,
    Cos-enfrance
    Plumbers Arms member Centralheatking's Avatar
    West Lancashire
    738
    Pressure reducing valves generally need to be installed with the head NOT downwards cause
    crap from the main can jam them up. Even so they actually a device that requires servicing
    from time to time. You can generally open them up and clean them out or just go and get
    another. Honeywell do4 is the best we have used - very smooth adjuster and not too
    pricy compared to far eastern copies which are only £5 less.
    centralheatking
    Jan 2012
    Essex
    3,201
    Default
    The useful life of a PRV or gauge depend on several factors.
    Quality of gauge/PRV.
    Hardness of water supply
    Quality of water supply (silt etc)
    High usage of water (wears out)
    Very low usage of water (seizes up)
    Extreme variations in incoming pressure.
    And probably many other factors I haven't thought of.
    It might be worth disconnecting it and seeing if the filter (if any) is partially
    blocked.
    MM
    Aug 2012
    Quote Originally Posted by Centralheatking View Post
    centralheatking
    Many thanks for that info.
    Aug 2012
    blocked.
    MM
  9. The Following User Says Thank You to Cos-enfrance For This Useful Post:
    Centralheatking (12-08-2012)
  1. Recommended domestic water pressure.
    By jackplumb in forum Plumbing Forum
    Last Post: 17-01-2012, 08:19 AM
  2. Pressure Reducing Valve
    By Jamiealex12 in forum Plumbing Forum
    Last Post: 18-04-2011, 10:53 PM
  3. reducing water pressure
    By apcdave in forum Bathrooms, Showers and Wetrooms
    Last Post: 17-04-2011, 12:43 PM
  4. High mains water pressure need reducing?
    By bodsmate in forum Plumbing Forum
    Last Post: 13-06-2010, 07:42 PM
  5. Help-Domestic system, hot water pressure
    By Les in forum Plumbing Forum
    Last Post: 03-09-2009, 10:18 PM
reducing domestic water pressure in uk
how do you reduce pressure in domestic plumbing
domestic water pressure france
