Results 1 to 11 of 11
Plumbing & Plumbers Forum - Sime Halstead Trio expansion vessel
Discuss Sime Halstead Trio expansion vessel in the Plumbing Forum at Plumbers Forums; Hello all, I have got to replace a expansion vessel on a Sime boiler. It's an internal one situated at the back of the boiler itself. The original one has ...-
09-08-2012 #1Plumbers Arms member
- Feb 2012
- Gloucestershire
- 839
- 107
- Thanked 77 Times in 76 Posts
Hello all,
I have got to replace a expansion vessel on a Sime boiler. It's an internal one situated at the back of the boiler itself. The original one has a pinhole leak in it, therefore needs replacing.
Has anyone had any experience of replacing one of these that could give me some pointers as to the best way to go about it.
I have ordered the replacement already, so it's all ready to go.
Thanks in anticipation
Tom
09-08-2012 #2Top Plumbing Forum Contributor
- Feb 2011
- 664
- Thanked 75 Times in 72 Posts
Re: Sime Halstead Trio expansion vessel
As you already have the replacement coming, all you have to do is remove the boiler from the wall, fit the new vessel, refit the boiler.
There is an easier way but you've paid for the replacement now.
Most important tho' is to make sure whoever refits the boiler is GasSafe registered and checks that the flue is reinstalled correctly.
09-08-2012 #3Plumbers Arms member
- Feb 2012
- Gloucestershire
- 839
- 107
snowhead, thank you for replying.
What's the easier way? The vessel can always be returned!
I was hoping that there was a way of fitting the vessel without disturbing any of the gas carrying parts?!?
09-08-2012 #4UK Plumbersforums Trusted Advisor.
- Hastings
- 3,900
- 45
Fit a remote one.
09-08-2012 #5Plumbers Arms member
- Feb 2012
- Gloucestershire
- 839
- 107
How would I get to the pipework to the existing one to fit a remote one? (I take it by remote, you mean external?)
09-08-2012 #6Plumbers Arms member
- Nov 2011
- Redhill, Surrey
- 245
- 6
- Thanked 22 Times in 21 Posts
As the existing vessel is holed and leaking water you will have to replace it unless
the leak can be sealed.
Only then could an external vessel be fitted.
(the existing vessel is knackered an no repair can be made to get it back in use)
09-08-2012 #7Plumbers Arms member
- Feb 2012
- Gloucestershire
- 839
- 107
How is it possible to seal the leak on the vessel? Would it hold as a permanent fix or just temporary?
Is there any reasonably straight forward way of replacing the vessel without disturbing any gas carrying parts?
10-08-2012 #8UK Plumbersforums Trusted Advisor.
- Hastings
- 3,900
- 45
No, they're a pain in the neck which is why people like to fit an external one.
11-08-2012 #9Plumbers Arms member
- Feb 2012
- Gloucestershire
- 839
- 107
Still looking for some advice on this one guys!!
Has anyone on here worked on this type of boiler before?
Really need a way of changing the vessel without disturbing any gas carrying parts!
11-08-2012 #10UK Plumbersforums Trusted Advisor.
- Hastings
- 3,900
- 45
There isn't one. Your only hope is to cap off the pipe leading to it and fit an external one if you can get access.
11-08-2012 #11Plumbers Arms member
- Feb 2012
- Gloucestershire
- 839
- 107
Or pass it on to a GSR installer? Sounds like I need to walk away from this pretty quickly!!
Converting to sealed system and expansion vessel vessel sizing
By westyvip in forum Central Heating ForumReplies: 12Last Post: 13-01-2012, 01:13 AM -
Halstead Platinum expansion vessel access
By pauln in forum Central Heating ForumReplies: 4Last Post: 06-01-2012, 01:45 PM -
expansion vessel
By jambo in forum Central Heating ForumReplies: 14Last Post: 28-01-2011, 01:30 AM -
Poor hot water - Sime Halstead Trio boiler
By dleader in forum Central Heating ForumReplies: 1Last Post: 21-12-2010, 08:37 PM -
Looking for timer clock pins for my sime halstead
By newbie123 in forum Central Heating ForumReplies: 1Last Post: 03-10-2010, 01:05 AM
My work is drying up???? Help...
3 Minutes Ago in Plumbing Forum
