Results 1 to 6 of 6
Plumbing & Plumbers Forum - Shower waste location
  • 1 Post By REDSAW
Discuss Shower waste location in the Plumbing Forum at Plumbers Forums; Advice please. When facing the shower, which corner should the waste be in, or is just a matter of which is most convenient to run the waste pipe from?...
    Default Shower waste location
    Top Plumbing Forum Contributor Paulus's Avatar
    Oct 2010
    Cheshire
    662
    Default Re: Shower waste location
    The tray will have a fall on it to the waste so wherever its easiest to run the waste pipe.
  3. If we find we cannot help others, the least we can do is to desist from harming them. Dalai Lama.
    Plumbers Arms member Plum Bob 66's Avatar
    Lincolnshire and proud to be a yellow belly
    502
    Might be worth while thinking about access to the trap at a later date, should there be a leakage issue.Went to a custard today whose shower trap had leaked under the floor into the next room, not pretty. Waste was at back of shower with tray plumbed on to wooden plinth with not a hope of access, whole things got to come out !! She was not amused..
    Many thanks for the responses - we will locate the waste at the front corner nearest the outside wall.
    SUPER MODERATOR
    REDSAW's Avatar
    Jan 2009
    sherrif county
    9,119
    technically, the trap far away from shower exit as possible to prevent slipping in water when exiting.
    pratically, nearest place possible for trap maintenance.
    Phil likes this.
    ¿ʞɹoʍ sɐƃ
    Apr 2008
    West Yorkshire
    2,034
    Yes, I like to do mine with the plughole over the shower aswell if we're talking a standard 1200x800 with the door at the other end.
    Tray sat on floor and waste straight over joist position, I wouldn't have it any other way.
  1. Shower waste
    By johnston in forum Bathrooms, Showers and Wetrooms
    Last Post: 31-01-2012, 10:35 AM
  2. Shower waste
    By mipar in forum New Member Introductions
    Last Post: 24-10-2011, 10:58 PM
  3. sink and shower waste?
    By johnston in forum Plumbing Forum
    Last Post: 12-01-2011, 11:12 PM
  4. Shower waste
    By notaclue in forum Bathrooms, Showers and Wetrooms
    Last Post: 29-03-2010, 09:31 PM
  5. shower pump location
    By bez7409 in forum Bathrooms, Showers and Wetrooms
    Last Post: 10-03-2010, 08:34 AM
waste location in shower
shower waste location
plumbing tips for shower waste
shower waste locations
position of shower waste traps
correct position for shower waste
