Results 1 to 11 of 11
Plumbing & Plumbers Forum - Leak in water line?
Leak in water line?
Discuss Leak in water line? in the Plumbing Forum at Plumbers Forums; Hello, I have a flat where a water meter was put in a few months ago. This has been inserted below the bath where the water line comes in a ...-
09-08-2012 #1Steady Plumbing Forum Contributor
- Nov 2011
- 171
- 33
- Thanked 1 Time in 1 Post
Leak in water line?
Hello,
I have a flat where a water meter was put in a few months ago. This has been inserted below the bath where the water line comes in a 2 bed terraced flat. Basically as far as I can tell the water piper just go from the bathroom to the next room which is the kitchen where the Combi is. Then the combi pipes go into the other rooms. Now there can't be a leak on the combi pipes as then the pressure on the boiler would go down, anyway that's a sealed unit. So there must be a leak in either the kitchen or bathroom. I have had a quick visual look and can't see anything.
The meter turns around 3 bars every hour. When you flush it it turns around 8. So I estimate around a liter of water leakage per hour according to the meter?? Am I right? The flooring in the kitchen and bathroom is cemented. There is no damp or signs of water leakage. Surely 1 liter per hour would show up somewhere after a few months?
What can I do to trace the leak? How do these water meter's work? Since its inside the flat will it tick if there is a leak outside below the rear yard Not that I have seen any signs of it there.
09-08-2012 #2Moderator
- Jul 2010
- Portadown, United Kingdom
- 7,667
- 446
- Thanked 533 Times in 494 Posts
Re: Leak in water line?
What pressure is your combi sitting at? Your fill loop may be passing and throwing water out the pressure relief.
Croppie
(By the way, I'm commercial!)
09-08-2012 #3Plumbers Arms member
- Feb 2011
- The Land Of The Prince Bishops
- 7,231
- 284
- Thanked 691 Times in 681 Posts
Toilet not overflowing?
Rule out all the obvious stuff before you start hacking up concrete floors.If You Burn It, It Can Kill You.
09-08-2012 #4Steady Plumbing Forum Contributor
- Nov 2011
- 171
- 33
09-08-2012 #5Plumbers Arms member
- Jul 2010
- Horsham, West Sussex.
- 2,048
- Thanked 162 Times in 162 Posts
09-08-2012 #6Plumbers Arms member
- Apr 2008
- West Yorkshire
- 2,034
- 232
- Thanked 101 Times in 97 Posts
Yep, probably a new age 'water saving' flush valve assembley thats dumping 24 litres of clean fresh drinking water into the sewers everyday.
09-08-2012 #7Top Plumbing Forum Contributor
- Apr 2011
- 751
Have a look in your toilet cistern and see what is happening
09-08-2012 #8Steady Plumbing Forum Contributor
- Nov 2011
- 171
- 33
I will have a look at the toilet first and update. Thanks
11-08-2012 #9Steady Plumbing Forum Contributor
- Nov 2011
- 171
- 33
11-08-2012 #10Plumbers Arms member
- Apr 2008
- West Yorkshire
- 2,034
- 232
One trick I like to do is to get a long screwdriver and hold it against the mains pipe downstairs and press the handle to your ear, if water is being used you will hear it.
Make sure nothing is being used though.
11-08-2012 #11Steady Plumbing Forum Contributor
- Nov 2011
- 171
- 33
HEAT LINE C28 no hot water
By MMB in forum Central Heating ForumReplies: 10Last Post: 29-07-2012, 12:00 PM -
Water leak
By leslie50 in forum Plumbing ForumReplies: 13Last Post: 26-07-2012, 12:18 PM -
Possible water in the oil line?
By Millsy 82 in forum Oil and Solid Fuel ForumReplies: 6Last Post: 19-07-2012, 08:12 PM -
Ondemand In-Line Hot Water Advice
By brooky in forum Plumbing ForumReplies: 1Last Post: 28-06-2008, 08:06 PM
1Likes
worcester 24 ri or system 24i
3 Minutes Ago in Gas Safe Register Forum - Public Forum
