Results 1 to 9 of 9
Plumbing & Plumbers Forum - Dishwasher waste to a 32mm pipe?
Discuss Dishwasher waste to a 32mm pipe? in the Plumbing Forum at Plumbers Forums; A client wants his dishwasher waste pipe connected to his washbasin, which exits in 32mm. Knowing that it's supposed to go into 40mm, I wonder if I can do that? ...-
06-08-2012 #1Steady Plumbing Forum Contributor
- Jun 2012
- Croydon, Surrey
- 145
- 16
- Thanked 6 Times in 6 Posts
Knowing that it's supposed to go into 40mm, I wonder if I can do that? I mean practically, sure, but is it a very bad idea, or is it OK?
What do you guys think?
06-08-2012 #2Plumbers Arms member
- Apr 2008
- West Yorkshire
- 2,034
- 232
- Thanked 101 Times in 97 Posts
Re: Dishwasher waste to a 32mm pipe?
In an ideal world 40mm but sometimes you have make the best of what you have to work with, just make sure its not a long flat tourturous length and the wash basin drains nicley.
06-08-2012 #3
It'll probably pull the trap seal out on the basin.
My other car is a horse
06-08-2012 #4Plumbers Arms member
- Aug 2011
- Hertfordshire
- 1,815
- 34
- Thanked 101 Times in 99 Posts
My mum and dads w/m pipe discharges into the basin waste and has done for years do problems. ps i didnt do it by the way
If i dont need a hammer i dont want the job
06-08-2012 #5Steady Plumbing Forum Contributor
- Jun 2012
- Croydon, Surrey
- 145
- 16
06-08-2012 #6Plumbers Arms member
- Jun 2012
- London/Kent
- 1,719
- 102
- Thanked 183 Times in 179 Posts
It will pull the trap!! but only after it has pumped the discharge from the machine back up into the basin (probably, depending where the connection id made). It not only should be 40mm but it should also be on it's own run to the stack, it may not be a problem when it is installed but any build up on the inside walls of the waste will cause problems later. Don't do it tell them it needs to be installed correctly (In line with Part H of the building Reg's).
07-08-2012 #7Top Plumbing Forum Contributor
- Oct 2010
- Cheshire
- 662
- 51
- Thanked 97 Times in 94 Posts
with Chris. If they still insist on going into 32mm I would still do the job as they want but make sure they understand the possible consequences. I would put it in writing so they can't deny your advice in the future if problems occur. If you don't do the job, somebody else will and you could lose a future customer.
If we find we cannot help others, the least we can do is to desist from harming them. Dalai Lama.
07-08-2012 #8Plumbing Forum Contributor
- Mar 2012
- 40
- Thanked 1 Time in 1 Post
Its bad practice but you will probably get away with it.
I personally don`t think it will blow the seal out the trap, but that does depend on how its been ran.
You could always use a hep vo check valve if you was concerned, I`m sure they are available in 32mm.
07-08-2012 #9Plumbers Arms member
- Jun 2012
- London/Kent
- 1,719
- 102
They are & you could, use one. A water filled trap would more likely self-siphon rather than blow out but either way Hep vO trap on the basin waste fitting would do the trick, good call dsteves619.
If you are going to do it, just take care that the washing machine outlet hose is not air as it connects to the 32mm waste.
Need to drill a hole in tiled wall for 32mm waste pipe...
By WaterTight in forum Plumbing ForumReplies: 12Last Post: 28-02-2012, 07:43 PM -
32mm waste pipe into old cast iron stack
By ChrisCTK in forum Plumbing ForumReplies: 10Last Post: 12-12-2011, 12:18 AM -
Dishwasher - waste pipe wrong type for fitted trap
By ivrytwr3 in forum Plumbing ForumReplies: 2Last Post: 30-10-2010, 11:34 PM -
Washing Machine/Dishwasher Waste Pipe
By Tom Edwards in forum Fittings & PipesReplies: 7Last Post: 08-04-2010, 09:03 PM -
Toilet and 32mm waste into same pipe
By MikeHowles in forum Plumbing ForumReplies: 4Last Post: 10-05-2009, 08:25 PM
1Likes
Cold Radiators
7 Minutes Ago in Central Heating Forum
