Results 1 to 15 of 28
Plumbing & Plumbers Forum - Working on bath hot water pipe
Discuss Working on bath hot water pipe in the Plumbing Forum at Plumbers Forums; I changed my bath shower mixer tap in my upstairs bathroom at the weekend but my pipework is imperial three quarter inch and I couldn't stop the tap connector from ...-
06-08-2012 #1New to Plumbing Forum
- Aug 2012
- 9
I changed my bath shower mixer tap in my upstairs bathroom at the weekend but my pipework is imperial three quarter inch and I couldn't stop the tap connector from leaking. The access is really tight so I couldn't get the PTFE tape to the threads despite trying for hours. I spoke to a friend who recommended cutting the pipe down and using a flexi tap connector how stupid was I to take that advice the compression joint to the pipe appears to be ok but when I turn the water back on it still has a very slight leak. I tried PTFE around the olive which worked but then the water very slowly seeped out of the top of the nut. I read this forum changed the olive and bought some LSX. Now the slight leak is back at the olive. I will probably go back to using copper pipe but my problem is that since I cut the pipe there has been water which sits at the top of the cut and if I soak it up the water goes down the pipe for a second then comes back so I have to work with a bath towel and various cloths which become saturated really quickly. This seems like a gravity problem but I don't understand why there is so much water. I have made sure that the hot and cold valves on the cylinder are turned off completely and have left all the hot taps in the house open but it makes no difference. Does this mean that my shut off valve isn't working properly or could something else be going on.
06-08-2012 #2Plumbers Arms member
- Feb 2011
- The Land Of The Prince Bishops
- 7,219
- 284
- Thanked 691 Times in 681 Posts
Re: Working on bath hot water pipe
I honestly think you should bite the bullet and get a plumber in. Post your location, somebody on here may be close enough to help.
06-08-2012 #3New to Plumbing Forum
- Aug 2012
- 9
Thank you for your reply but I am not in a position to do that. I am quite competent at pipework and changing taps and valves. I just need to understand what is going on with the water in the pipe.
06-08-2012 #4Moderator
- Nov 2007
- hythe hampshire
- 8,971
- 444
- Thanked 746 Times in 726 Posts
it does sound like your gate valve on the hot side is letting by
06-08-2012 #5Plumbers Arms member
- Feb 2011
- 7,219
- 284
Best of luck.
06-08-2012 #6Super Plumbing Forum Contributor
- Feb 2009
- Liverpool
- 1,972
Hmm! Are you using an imperial ring when you connect the metric fitting on to the imperial pipe? I know metric nuts and rings fit on imperial pipe but you have problems with leaks like you seem to be having. Some compression fittings you may have to change the back nut as well.
06-08-2012 #7Top Plumbing Forum Contributor
- Oct 2010
- Cheshire
- 662
- 51
- Thanked 97 Times in 94 Posts
Have you opened your downstairs taps to drain off the water retained in the pipes?
If we find we cannot help others, the least we can do is to desist from harming them. Dalai Lama.
06-08-2012 #8New to Plumbing Forum
- Aug 2012
- 9
Hi, thanks for your reply. I am using a 22mm to 3/4 inch flexible tap connector and the olive is therefore imperial size.
06-08-2012 #9New to Plumbing Forum
- Aug 2012
- 9
Yes I opened all the hot water taps upstairs and downstairs. Thanks anyway.
06-08-2012 #10New to Plumbing Forum
- Aug 2012
- 9
Thanks for your reply. I did think that this might be the problem but hoped that it was accumulated water in the pipes somehow being caught in a vacuum and that there might be a solution.
06-08-2012 #11New to Plumbing Forum
- Aug 2012
- 9
Read more: http://www.ukplumbersforums.co.uk/pl...#ixzz22lRCSR7f (Working on bath hot water pipe)
06-08-2012 #12
06-08-2012 #13Super Plumbing Forum Contributor
- Jun 2012
- 1,450
- 12
- Thanked 125 Times in 120 Posts
Have you opened up any showers on the system - put the shower head in the tray or the bath so that it drains.
Also, have you tried opening and closing the valves several times - gate valves in hard water areas are buggers for letting water pass when they haven't been used for a while.
If you've done all of the above with no success - switch off at the main stopcock and drain the system.
As for the leaking olive, I'd be inclined to start again with a new olive - clean the pipe with some wire wool, make sure the surface is good, and then wack it up tight with a new olive and forget the tape.
If that fails, go for a good quality 3/4" push fit.******************** http://www.comodo.com/home/browsers-...rs/browser.php ********************
06-08-2012 #14New to Plumbing Forum
- Aug 2012
- 9
06-08-2012 #15New to Plumbing Forum
- Aug 2012
- 9
waste pipe under bath
By Werth in forum Plumbing ForumReplies: 9Last Post: 01-04-2012, 03:42 PM -
gravity hot water not working, pumped central heating working
By njk in forum Central Heating ForumReplies: 9Last Post: 18-12-2011, 12:24 PM -
Help - Bath/shower triple valve issue - cold water eliminating hot water.
By olfrog in forum Plumbing ForumReplies: 5Last Post: 16-10-2011, 07:20 PM -
Is there a plumbers trick for working out what is in a pipe?
By olfrog in forum Plumbing ForumReplies: 12Last Post: 23-12-2010, 06:18 PM -
Waste Pipe Run For Bath
By DazJWood in forum Plumbing ForumReplies: 4Last Post: 14-01-2010, 11:23 AM
8Likes
Oil Tank Pipe work.
3 Minutes Ago in Oil and Solid Fuel Forum
