Plumbing & Plumbers Forum - Hole in outdoor waste pipe from kitchen sink
Discuss Hole in outdoor waste pipe from kitchen sink in the Plumbing Forum at Plumbers Forums; Hi, We are having a deck fitted and so wanted to get rid of the ugly pipe which comes from our condensing boiler out to our waste pipe from our ...
    Jul 2012
    Default Hole in outdoor waste pipe from kitchen sink
    We are having a deck fitted and so wanted to get rid of the ugly pipe which comes from our condensing boiler out to our waste pipe from our kitchen. I have removed the condemning pipe but we are now left with a small hole in the side of the waste pipe and I am not sure how we are best to seal it. The deck panels will be over the top of the hole and there is currently a slight leak from the hole when we run the tap down the drain and so we don't want to leave it. I was thinking of using some water proof tape to seal the hole but wasn't sure if there is a better solution. Any advice anyone could give would be appreciated.
    Many thanks,
    Jamie.
    Mike Jackson's Avatar
    Hastings
    3,892
    Default Re: Hole in outdoor waste pipe from kitchen sink
    Cut the pipe out and replace it. What have you done with the condense from the boiler?
  3. Gas Safe Registered Engineer for all your Domestic gas, Heating and plumbing needs in Hastings, East Sussex. Check me out on the Gas Safe website, reg. No. 537192.
    croppie's Avatar
    Portadown, United Kingdom
    7,586
    Quote Originally Posted by Mike Jackson View Post
    I was thinking that too.
    Croppie
    (By the way, I'm commercial!)
    east london
    6,666
    cemented over im sure cant have nasty pipes ruining the look of the new deck
    ps decks are so nineties
    Jul 2012
    Thanks for the reply Mike, the problem with replacing the pipe is the frame of the deck is already down and it is right in front of where is hole is so it is going to be hard to replace I think. As a makeshift solution, do you think waterproof tape will work? There's no pressure coming from the hole, even when I run the tap in the kitchen on full, it just trickles out so I am assuming the tape wil deal with that kind of pressure?
    Regarding the condensing pipe, we are routing it inside so it runs to the waste pipe through the house.
    Jamie.
    Jan 2011
    Charing
    593
    Its just watering my roses for me!!
    Got a Alpha boiler with a problem, then you need help from Alpha man! Covering all areas in Kent and stock carried on the Van.
    Steve
    Mar 2012
    40
    You could try using a slip coupling.
  1. kitchen sink waste pipe size
    By sparky in forum Plumbing Forum
    Last Post: 23-02-2011, 07:29 PM
  2. Best thing to seal kitchen sink plug hole?
    By rking100 in forum Plumbing Forum
    Last Post: 11-08-2010, 02:05 PM
  3. Kitchen Sink Waste
    By ChipRivers in forum Plumbing Forum
    Last Post: 30-09-2009, 08:09 AM
  4. kitchen sink waste
    By cosmicnur in forum Plumbing Forum
    Last Post: 15-09-2009, 08:01 AM
kitchen waste hole
kitchen waste pipe sizes
how to plumb a sink waste into a waste pipe
decking waste pipes
how to fix outdoor waste pipe
replace old sink waste pipe
how to repair outside kitchen sink pipe
