Results 1 to 15 of 22
Plumbing & Plumbers Forum - Water Pressure Suddenly Dropped in Bathroom!!!!
Discuss Water Pressure Suddenly Dropped in Bathroom!!!! in the Plumbing Forum at Plumbers Forums; Hi All, I live in a flat and over the Jubilee weekend I went to have a shower and the water pressure had dropped so low that the shower was ...
    13
    Default Water Pressure Suddenly Dropped in Bathroom!!!!
    Hi All,
    I live in a flat and over the Jubilee weekend I went to have a shower and the water pressure had dropped so low that the shower was unusable. My shower is just one of those hoses off of the bath mixer tap but it had been working very well and now it just trickles out. On closer inspection the cold water pressure in the adjacent sink (mixer tap) had also dropped.
    I hasten to add that the hot water pressure is absolutely fine but the cold water is the problem and extremely low, hence the shower not working properly. Basically once the cold tap is turned on it's basically either off or on a very very low flow (not a trickle but low flow) and is nonadjustable.
    The kitchen tap works absolutely fine so it's not the mains water that's the problem but more the cold water supplied from my water tank above the bathroom, I also have a combi boiler.
    Anyway it's been a few weeks now and it looks like I'm going to need to get a plumber in but before I do I wondered if there was anything I could do to try and resolve the problem myself. Since I'm probably going to get someone in I thought that it doesn't matter if I bugger it up but I always like to try to attempt things first myself.
    Has anyone got any suggestions or advice as to what I could try or what it could be before I start looking for a plumber?
    Many thanks
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,969
    Default Re: Water Pressure Suddenly Dropped in Bathroom!!!!
    sounds like the washer on the cold side needs looking at
  3. GSR?want gas safety or boiler repair advice?we will check out that your genuine via the gas safe website,so please don't be offended when we ask for your details. diyers, bodgers, odd job people and have a go heroes need not apply
    13
    Quote Originally Posted by steveb View Post
    Thanks for replying, do you mean on the taps or the storage tank? Is this something I could potentially do myself?
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,969
    most likely on the tap. yes it's something you can do yourself
    Simon F's Avatar
    Nottingham
    1,416
    Quote Originally Posted by alexb View Post
    this is a strange set up, if not as Steve suggested then it could be a blockage in the pipe from the storage tank.
    Why has it been done this way, hot from the combi and stored cold?
    13
    Quote Originally Posted by Simon F View Post
    Thanks, I will have a look when I get home and check the washers. The only thing is that the water pressure has gone on the cold water on the bath/shower mixer tap and the sink mixer tap as well. These are only a year or two old so is it likely that the washers would both go on exactly the same day?
    With regards to the combi/storage tank, I'm not sure why it is set up like that. Originally there was just a regular boiler and then when that went it was replaced with a combi boiler but I guess the setup wasn't actually changed over. Having said that, I think though that the cold water still runs through the combi even though it's initially coming from the water tank or does that sound like complete rubbish!
    I hasten to add that I have no experience whatsoever with plumbing so this is all from my very uninformed mind!
    Top Plumbing Forum Contributor Paulus's Avatar
    Oct 2010
    Cheshire
    662
    The first thing you need to do is confirm where the cold feed to the tap and shower come from. Turn off your wter supply at the mains and see if this stops the cold water flow to the shower and tap completely. If it does, you have mains water pressure to both and it sounds like you have a blockage in the cold water mains supply.
    If turning off the mains doesn't affect the cold water flow the shower and tap are tank fed (which I doubt) and you have a blockage between the tank and the bathroom.
    If we find we cannot help others, the least we can do is to desist from harming them. Dalai Lama.
    13
    Quote Originally Posted by Paulus View Post
    Ok that makes sense. I do think that it's tank fed though as when you put the cold tap on I can hear the water tank filling back up which I don't get from the kitchen tap. Assuming its from the tank is it possible to clear a bloackage without a plumber?
    Oct 2010
    Cheshire
    662
    The easiest way would be to open the tap and blow air or water up from the tap to the tank. Maybe use a hosepipe connected to the kitchen tap for this. Be prepared for a soaking.
    It would be best to get a plumber in to clear the blockage and connect your bathroom cold water supply to the mains. It shouldn't take very long.
    13
    Thanks for all your advice regarding this. I had a look last night and the water tank is supplying the bathroom toilet, bath and sink. I didn't realise that with a combi boiler that it should all now come from the mains supply. I do live on the 4th floor of a very old mansion block of flats (c1900) so there may be logistical problems as to connecting it to the mains supply.
    I didn't have a hose to hand but I unscrewed the shower attachment and put my hand over the hole, turned on the cold tap then the hot and didn't allow water to escape. I was hoping that this may clear the blockage but it doesn't seem to so I will have to get someone in now, just hope it isn't too expensive!!!
    east london
    6,666
    do you have individual tanks or shared? has anyone else in the block had similar problems
    if it individual i would get it crossed over to give you mains cold water it could be done with an eye to returning it to tank should you get water supply problems
  13. #12
    13
    Thanks for your message.
    The water tanks are individual, mine is located in a cupboard at the top of my bathroom which I can access.
    I will suggest getting it hooked up to the mains, is this usually an expensive job though or is it relatively simple? Presumably if I do this then I just have an empty water tank in the cupboard.
  14. #13
    Oct 2010
    Cheshire
    662
    It should be simple job, though it's difficult to say without seeing it. Cut mains pipe feeding the tank and connect to outlet pipe to bathroom. Yes, you will then have a redundant water tank in the cupboard.
  15. #14
    east london
    6,666
    if its in your cupboard im suprised you ever had enough pressure for a shower should be easy to cross the main to the cold feed
  16. #15
    13
    Thanks guys, I have left a message with a plumber so am waiting to hear back now.
    To be honest the water pressure on the cold tap has never been great except prior to having the combi boiler but it was still sufficient for the shower I have. Obviously now it's non existent. It's a shame that this wasn't flagged when I had my new bathroom installed a couple of years ago, they wanted to install a pump (which didn't happen), sounds like it would have been easier to just redirect the pipes to the mains.
  1. Mixer shower pressure dropped!
    By webfox in forum Bathrooms, Showers and Wetrooms
    Last Post: 25-11-2011, 03:14 PM
  2. Suddenly no water pressure???
    By Alan Cordt in forum Plumbing Forum
    Last Post: 15-08-2011, 10:21 PM
  3. Hot water suddenly just trickling into bath ??
    By wyoping23 in forum Valves & Taps
    Last Post: 09-06-2011, 10:05 PM
  4. Replies: 10
    Last Post: 11-01-2011, 09:44 PM
  5. Mixer shower pressure dropped
    By Splont in forum Bathrooms, Showers and Wetrooms
    Last Post: 22-06-2009, 07:35 AM
why has my water pressure suddenly dropped
loss of water pressure in bathroom
just had bathroom done and water pressure on taps and shower is now non-existent what can i do
pressure drop on cold tap
water pressure dropped suddenly
low cold water pressure in bathroom
water pressure suddenly drops
