Results 16 to 30 of 30
Plumbing & Plumbers Forum - Servicing your own vans
Discuss Servicing your own vans in the Plumbing Forum at Plumbers Forums; Originally Posted by gas man use a proper jack and axle stands dont compromise on your safety,if you were closer you could borrow my wind back tool use some copper ...-
30-07-2012 #16UK Plumbersforums Trusted Advisor.
- Hastings
- 3,895
- 45
Re: Servicing your own vans
30-07-2012 #17UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,039
- 501
- Thanked 676 Times in 610 Posts
My goodness!!
The stick we give people for doing diy plumbing, safety and all that ...
Now: what were those YouTube videos again?I'm not a complete idiot; some parts are missing
30-07-2012 #18Plumbers Arms member
- Apr 2008
- West Yorkshire
- 2,034
- 232
- Thanked 101 Times in 97 Posts
In the past I've done all sorts to my cars, head gasket, brakes, full respray, torsion bars etc....
Diy on your own car can be dangerous as I found out when I removed the front spring without clamps and nearly took my 8a57ard head off.
30-07-2012 #19UK Plumbersforums Trusted Advisor.
- Dec 2009
- Coatbridge, Lanarkshire
- 3,515
- 52
- Thanked 341 Times in 314 Posts
whats your opinion on DIY gas work re it being a risk to the general public/neighbours of the job as by definition DIY isnt an expert, so you want to watch a video on you tube then change a safety critical part on a vehicle that you intend to drive around town, as we say on here leave it to the expert, if you crach and they check the brakes and find the critical safety pin is in backwards and that caused the slippage that lead to the crash you could go to jail (or the mortuary)
06-08-2012 #20Plumbers Arms member
- Jun 2009
- Hampton court, Surrey
- 1,602
- Thanked 42 Times in 42 Posts
Thanks for all the replies guys. I had a go this weekend and got stuck on the first dic! The disc retaining screw was rusted on so tight that i end up shaving the shape of the star into a circle. So, am thinking they're all like this and have ordered some of these screws and then i shall proceed to drill them out. Hopefully this weekend!! If the wife hasn't planned anything
06-08-2012 #21Super Plumbing Forum Contributor
- Jun 2012
- 1,450
- 12
- Thanked 125 Times in 120 Posts
Not sure which screws you mean - but some sharp taps on a sturdy Phillips (+) screwdriver will sometimes help to release such screws. Better still is a Phillips bit in a socket driver - give it several sharp taps in succession.
If it's the screws in the rear drums, this will often do the trick. A pair of mole grips on the shaft of the driver often helps as well.******************** http://www.comodo.com/home/browsers-...rs/browser.php ********************
06-08-2012 #22Plumbers Arms member
- Jun 2009
- 1,602
cheers for the info
06-08-2012 #23Plumbers Arms member
- Nov 2011
- Manchester
- 238
- Thanked 14 Times in 13 Posts
I always use an impact screwdriver for those and always the correct PH/PZ bit for the screw. I have had to cut a few discs off before, they have been so far past needing replacement though
23-08-2012 #24Plumbers Arms member
- Jun 2009
- 1,602
well I serviced my own van last week and it went for its MOT today and it failed!! I changed front and back disk brakes and pads and oil. And it fails on worn ball joints. I just knew it!! It always happens. You save yourself a bit of money on one thing and something else just pops up to take that sense of achievement away. Gutted!
Am still chuffed I did the disk and pads though. It is still a saving really. isn't it??????????????/
23-08-2012 #25Super Plumbing Forum Contributor
- Jun 2012
- 1,450
- 12
As it passed on the brakes, your sense of achievement should still stand.
Are you going to do the ball joints yourself?******************** http://www.comodo.com/home/browsers-...rs/browser.php ********************
23-08-2012 #26
Im a car mechanic by trade i will be doing all my own work on my car lol
23-08-2012 #27Plumbers Arms member
- Jul 2011
- Wales
- 801
- 11
- Thanked 60 Times in 58 Posts
Always work on my own cars and vans. Brakes are easy to change, you shouldn't need a rewind tool if you're doing front brakes. The piston should just push back into the caliper. Check the level on the brake fluid reservoir as you do this, it will rise, if the reservoir has been topped up when the pads were low, it may overflow.
Remove as much debris from the pad carriers as possible with a small wire brush, and apply a smear of copper grease to the back of the pads and where the pads come in to contact with the carrier.
Discs usually come with an oily coating, this needs to be removed with brake cleaner and a cloth. After assembly, pump the brake pedal several times before setting off until firm and remember new brakes need bedding in, so take it easy and brake early.
I can highly recommend Pagid brake parts from eurocarparts.com.
Oops, hadn't realised you'd already done it, that'll teach me for not reading the whole thread!Last edited by R1CKY; 23-08-2012 at 10:29 PM.
23-08-2012 #28stratobuddyGuest
Are you VSR (van safe registered)?
23-08-2012 #29Plumbers Arms member
- Jul 2011
- Wales
- 801
- 11
No, but I used to be Corgi
www.vectis.co.uk/AuctionImages/80/1660_l.jpgLast edited by R1CKY; 23-08-2012 at 11:45 PM.
24-08-2012 #30stratobuddyGuest
What vans have you got?
By PatchettPlumbing in forum Plumbing ForumReplies: 53Last Post: 4 Weeks Ago, 08:43 PM -
organising vans
By cdodds2004 in forum Plumbing ForumReplies: 150Last Post: 18-07-2012, 12:35 AM -
vans
By sav in forum General Off-Topic ChatReplies: 2Last Post: 03-06-2012, 06:30 PM -
vans
By tonto33 in forum Plumbing ForumReplies: 19Last Post: 28-11-2010, 10:56 AM
3Likes
Man murdered in woolwich
8 Minutes Ago in General Off-Topic Chat
