Plumbing & Plumbers Forum - Pressure Gauge not responding to refill
Discuss Pressure Gauge not responding to refill in the Plumbing Forum at Plumbers Forums; Hi all, could you please, please help. The pressure gauge on my Vaillant 828 boiler stays put at 0.2 bar despite re-filling. That is, the needle does not rise with ...-
16-07-2009 #1New to Plumbing Forum
- Jul 2009
- 5
Hi all, could you please, please help. The pressure gauge on my Vaillant 828 boiler stays put at 0.2 bar despite re-filling. That is, the needle does not rise with rising water pressure. The question is: Is it the pressure gauge itself which is faulty or something else on the system ? AND if I should need to replace the pressure gauge how I should go about doing so ? What steps must I be taking ? Regards, wizarssaleem.
16-07-2009 #2Super Plumbing Forum Contributor
- Dec 2008
- 1,109
- Thanked 1 Time in 1 Post
Re: Pressure Gauge not responding to refill
has the system filled correctly as first test is at that low level i doubt it will fire up and tbh better to get an engineer if u cock it up it allways costs more to put something right
16-07-2009 #3New to Plumbing Forum
- Jul 2009
- 5
thanks for the prompt reply. The boiler is 4 years old and has been and still working perfectly despite displaying a very low reading.i tend to think that there is sufficient water hence enough pressure for the boiler to be working normally. Its just that the guage has stopped responding to the refilling.as a test i performed a measuerable refill to force up the guage needle but to no effect.however to be on the safe sode , i did subsequently drain out the excessive water to prevent any possible built up of high pressure inside the boiler. The boiler does refill and does work but guage does not. Any further thoughts, please?
With regards.
16-07-2009 #4Plumbers Arms member
- blackpool
- 2,139
- 4
- Thanked 10 Times in 8 Posts
guage is broken. replace it. fairly simple job. isolate boiler. release pressure. change.
good luck
shaun
17-07-2009 #5UK Plumbersforums Trusted Advisor.
- Hastings
- 3,893
- 45
I would think the most likely cause is a blockage in the capillary to the gauge. I've had this a few times in the past. It's worth checking the system water as it may be getting sludged up.
17-07-2009 #6Plumbers Arms member
- May 2009
- 7,303
- 218
Agree with Mike about blockage,this usually occurs at the point were the Gauge capillary pipe joins the main block of the boiler,you do not say make of boiler however drain boiler,unscrew/pull out capillary pipe and clean out end with a pin also clean out opening capillary pipe fits into
17-07-2009 #7New to Plumbing Forum
- Jul 2009
- 5
Thank you ALL for replying to my query. I am very grateful for your comments and suggestions. I will keep you posted as to how I get on.
Regards,
wizardsaleem
Vented / Unvented Mains pressure system
By phatz in forum Central Heating ForumReplies: 3Last Post: 14-07-2009, 05:49 AM -
Pressure not achieved from bore hole
By nads1978 in forum Plumbing ForumReplies: 0Last Post: 02-05-2009, 12:57 PM -
gravity HW & mains CW mixer tap problem
By MarkB in forum Valves & TapsReplies: 7Last Post: 23-03-2009, 11:51 AM -
combi boiler watere pressure gauge below 1
By corinnemunoz in forum Plumbing ForumReplies: 6Last Post: 09-02-2009, 06:47 PM -
Combined vent manifold & Pressure gauge
By johndallsop in forum Plumbing ToolsReplies: 0Last Post: 05-11-2008, 09:06 PM
Multifuel Stove - New Install
6 Minutes Ago in Oil and Solid Fuel Forum
