Plumbing & Plumbers Forum - How to make a "Stopper" for shower drain?? Advice needed
Discuss How to make a "Stopper" for shower drain?? Advice needed in the Plumbing Forum at Plumbers Forums; Hi guys, I've been having some problems with a shower drain back flowing. Original thread here if interested: http://www.ukplumbersforums.co.uk/pl...-new-post.html Great suggestions by a fellow member but unfortunately I'd rather not ...-
26-07-2012 #1New to Plumbing Forum
- Jan 2011
- 14
Hi guys,
Great suggestions by a fellow member but unfortunately I'd rather not dig everything up again.
I'm now trying to make a stopper for the drain so I can block it off when not using the shower and then removed it when needed (it's a guest shower so not used very often).
I have no plumbing experience whatsoever so would like some advice on what materials I need and how can I go about making the stopper. I attached a photo of the drain (apologies to the grime... didn't realise how dirty if was in there!). It's a bit awkward as the drain is on the side.
Thanks!
26-07-2012 #2Steady Plumbing Forum Contributor
- Oct 2010
- maidstone
- 121
- 10
- Thanked 5 Times in 5 Posts
Re: How to make a "Stopper" for shower drain?? Advice needed
I would still fit a hepvo. It stops smells and water coming back up your pipe work even if your trap dryers out as it is a guests shower and it conforms to regs.
27-07-2012 #3New to Plumbing Forum
- Jan 2011
- 14
yeah, a hepvo would be ideal but do you think I'll be able to fit one through the drain?
Pic attached
27-07-2012 #4Steady Plumbing Forum Contributor
- Oct 2010
- maidstone
- 121
- 10
If your going to rip it up any way then yeh why not.
27-07-2012 #5New to Plumbing Forum
- Jan 2011
- 14
no, as per my original post, I'd rather not rip everything up... The shower tray has been tiled over so to remove that I'd have to tear down the wall tiles as well.
"well i didn't think i needed a powerflush mate"
By moogwai in forum Central Heating ForumReplies: 10Last Post: 15-04-2011, 11:32 PM -
"""Pls help no hot water baxi 105e"""
By f1fanman in forum Plumbing ForumReplies: 3Last Post: 20-02-2010, 12:32 AM -
"Champagne"/"eco" shower heads?
By iBozz in forum Bathrooms, Showers and WetroomsReplies: 0Last Post: 09-11-2009, 03:33 PM -
"Water Hammer" Turning Faucet "ON" ?
By Robert11 in forum Plumbing ForumReplies: 3Last Post: 16-09-2009, 05:16 PM
Unvented direct cylinders in 5...
