Results 1 to 8 of 8
Plumbing & Plumbers Forum - Intermittent pressure of hot water from pump
Discuss Intermittent pressure of hot water from pump in the Plumbing Forum at Plumbers Forums; Hi, Forget I'm female, just help me out, guys, much appreciated! I've got a diagnostic query- Gravity hot water system to a pump for upstairs hot water only. The owner ...
    Apr 2009
    New Forest, Hampshire
    Default Intermittent pressure of hot water from pump
    I've got a diagnostic query- Gravity hot water system to a pump for upstairs hot water only. The owner reports intermittent fluctuations in pressure. There are no changes in pump noise when this happens. We thought it could be a foreign object that keeps blocking up at a certain bend or slight narrowing in the pipework. Flushing the hot feed from the cylinder to the pump hasn't worked, no visual signs inside the cylinder either. The pump seems to work straight away and continues when water on. Next thing is to change pipework from the cylinder to the pump which is now copper with a few 90 deg elbows. If no joy, thinking about perhaps the cold feed pipe. Any suggestions??
    Dec 2008
    1,109
    Default Re: Intermittent pressure of hot water from pump
    bit confused here gravity hot water thats fed to a pump??please dont get me wrong are you refering to the central heating pump?can you explain the system in a bit more detail
    May 2009
    7,303
    Is the hot supply pipework to pump direct from cylinder and connected to cylinder by surrey or essex flange,if not what is head betwwen cylinder and tank,what make of pump is it
    Ps why should we forget you are a female,lots of good female plumbers :-)
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    2,548
    I'd also check the NRV's on the shower, assuming it is connected to a shower
    Regards
    Tom
    Steady Plumbing Forum Contributor heinz57's Avatar
    Feb 2009
    Wales currently & proud to be English!
    115
    Is it a shower pump youre on about? Try checking the filters at the pump, they may
    be blocked slightly or there may be a filter in the shower unit that requires a
    good clean or maybe the shower head itself is a bit scaled up. Or as Plumbstar Tom
    suggested the NRV's.
    Apr 2009
    shower pump! It also feeds the hot water taps upstairs too-sorry not clear!
    Jul 2009
    Staffordshire
    2,548
    Hi
    Technically a shower pump should not boost taps as its designed for showers only. Ceramic disc taps cause problems with pumps in creating pressure waves. Do we have the connection yet? Surrey Essex? etc
    Regards
    Tom
    Apr 2009
    Hi, it's an Essex- off the side connection- correct county of choice?! I think this also feeds the rest of the upstairs taps-bath/ 2 basins too- they also have intermittent pressure fluctuations. Could these extra branches to taps be a cause? Maybe the shower pump can't cope-only supposed to be for the shower as one of you said? I'll find out the make. Ta for suggestions so far!
  1. Bungalow with requirement for instant hot water and more water pressure in bathrooms
    By David Salter in forum Bathrooms, Showers and Wetrooms
    Last Post: 06-10-2009, 11:56 PM
  2. Help! No hot water pressure!
    By lau89 in forum Plumbing Forum
    Last Post: 30-04-2009, 04:11 PM
  3. Hot Water Flow
    By southside in forum Bathrooms, Showers and Wetrooms
    Last Post: 27-04-2009, 09:15 PM
  4. gravity HW & mains CW mixer tap problem
    By MarkB in forum Valves & Taps
    Last Post: 23-03-2009, 11:51 AM
  5. Hot water pressure low
    By bladerunner in forum Plumbing Forum
    Last Post: 22-03-2009, 04:56 PM
hot water pressure low on shower intermittent
intermittent low hot water pressure
hot water pump intermittent
water pump intermittent on hot
shower water pump intermittent on hot
intermitant upstairs hot water pressure
