Results 1 to 15 of 20
Plumbing & Plumbers Forum - Toilets
Toilets
Discuss Toilets in the Plumbing Forum at Plumbers Forums; IMG_6041.JPG I have a customer who wants me to change the old WC above. He wants to use an Armitage Shanks Sandringham (as sold by B&Q in their 'bathrooms to ...-
25-05-2012 #1Plumbers Arms member
- Nov 2011
- Cheshire
- 453
- 126
- Thanked 35 Times in 35 Posts
Toilets
I have a customer who wants me to change the old WC above. He wants to use an Armitage Shanks Sandringham (as sold by B&Q in their 'bathrooms to go' range). The only problem is that I can't find out if this WC can cope with a vertical soil in the position it currently is (200mm from the centre line of the soil to the wall). Does anyone know if this loo will fit or have any links to installation dimensions for the AS Sandringham?
cheers
Matt
Plumbing and heating services in Warrington and throughout Cheshire
http://ospreyplumbing.co.uk/
http://www.facebook.com/OspreyPlumbingServices
Photography
http://mwetherill.com/
25-05-2012 #2Plumbers Arms member
- Jan 2012
- Essex
- 3,198
- 80
Use a 90degree extended multikwik to connect the pan to soil.
You may have to box in behind the cistern to pack out the wall.
The Following User Says Thank You to mountainman For This Useful Post:
MattWeth (25-05-2012)
25-05-2012 #3Top Plumbing Forum Contributor
- Feb 2011
- 657
- Thanked 75 Times in 72 Posts
Re: Toilets
Click on picture for detail of measurements;
ARMITAGE SHANKS SANDRINGHAM WCS AND BIDETS
The Following User Says Thank You to snowhead For This Useful Post:
25-05-2012 #4Plumbers Arms member
- Nov 2011
- Cheshire
- 453
- 126
Re: Toilets
Photography
25-05-2012 #5Plumbers Arms member
- Nov 2011
- Cheshire
- 453
- 126
Re: Toilets
Photography
25-05-2012 #6Top Plumbing Forum Contributor
- Apr 2011
- 751
Re: Toilets
You could try a swan neck pan connector,available from plumbfix (screwfix),it takes the pan back a little bit further,its shaped like a question mark,hope this helps
The Following User Says Thank You to glenno1 For This Useful Post:
25-05-2012 #7Plumbers Arms member
- Nov 2011
- Cheshire
- 453
- 126
Re: Toilets
Photography
25-05-2012 #8Moderator
- Feb 2010
- Alloa, Scotland
- 7,068
- 745
- Thanked 672 Times in 573 Posts
Re: Toilets
As Glenno says, use a swan neck and it will get you right back tight to the wall with the cistern. You can also cut a loo's spigot if you need to fit an extension to get back to the wall with a diamond tipped blade on a grinder, but practice on an old one first and use water sprayed on it as you cut!
Bathroom Design & Installation Specialists.
Over 34 years experience.
Rated People 5 Star Rating.
BY THE WAY I'M NOT COMMERCIAL. A flexible hose, gets up ma nose.
The Following User Says Thank You to system3 For This Useful Post:
25-05-2012 #9Plumbers Arms member
- Nov 2011
- Cheshire
- 453
- 126
Re: Toilets
Photography
25-05-2012 #10
25-05-2012 #11Moderator
- Feb 2010
- Alloa, Scotland
- 7,068
- 745
Re: Toilets
It's actually straight forward to cut one. As long as water is kept on it while cutting and a good quality diamond tipped blade is used. Fire clay drains can be cut like this too. Practice on an old one first!
Loos can be easily drilled too, using the drills from 365 drills.Last edited by system3; 25-05-2012 at 06:53 PM.
25-05-2012 #12Plumbers Arms member
- Aug 2010
- Glesca
- 773
- 35
- Thanked 75 Times in 73 Posts
Re: Toilets
i've looked at the sizes matt and i reckon you will have to box cistern out by around 65-75mm. the base of the pan is the problem, it will be right up against the cast iron soil pipe so your not going to gain anything by using a swan neck pan connector or cutting the pan spigot.
CONFUCIUS SAY- man with hole in trouser pocket, feel cocky all day,
man with 2 holes in trouser pocket, no feel too cocky.
32 years as a jazz drummer
& still dont know ma erse fae ma elbow
The Following User Says Thank You to johnnyplumb For This Useful Post:
25-05-2012 #13Plumbers Arms member
- Nov 2011
- Cheshire
- 453
- 126
Re: Toilets
Photography
25-05-2012 #14UK Plumbersforums Trusted Advisor.
- May 2008
- Bolton
- 4,170
- 190
- Thanked 350 Times in 330 Posts
As long as you don't do this..........
Sent from my GT-I9100 using Tapatalk 2IN CERVESA FELICITAS - IN BEER THERE IS JOY
I am responsible for what i say, i am not responsible for how much of it you actually understand
Brevior saltare cum deformibus mulieribus est vita
25-05-2012 #15Moderator
- Nov 2007
- hythe hampshire
- 8,969
- 441
- Thanked 746 Times in 726 Posts
Re: Toilets
that's very imaginative!
Getting a fall on a run of toilets
By camfish in forum Plumbing ForumReplies: 6Last Post: 16-08-2011, 06:13 AM -
Securing Toilets
By James O'Donnell in forum Sanitary WareReplies: 9Last Post: 18-02-2011, 01:37 AM -
Connecting two toilets
By bevan in forum Sanitary WareReplies: 10Last Post: 25-06-2010, 05:53 PM -
pub toilets
By Plumbstar Tom in forum Plumbing ForumReplies: 4Last Post: 16-06-2010, 01:33 PM -
Pub Toilets
By WHPES in forum Plumbing ForumReplies: 10Last Post: 14-04-2010, 09:01 AM
4Likes
Mixer shower & solid brick wall
3 Hours Ago in Bathrooms, Showers and Wetrooms
