Checkout the UKPF Chatrooms - Click Here
(Please ask any plumbing questions in the main forums, these chatrooms are for general banter)
Cold Water just wont shut down!!!! - Plumbing Forum | Free Plumbing Advice
Notices
Old 23-06-2009   #1 (permalink)
Pakamish
Info
Default Cold Water just wont shut down!!!!
All need some help. Im trying to replace my basin and I have the old copper pipes installed. So I went outside my flat and turned off the mains. I also turned off the stop valve under the kitchen sink. This stopped the hot and cold water for the kitchen and the hot water for the bathroom. for some weird reason the cold water in the bathroom keeps on running i found another hidden stop valve in the bathroom. Used all my strenth and half a bottle of WD 40. This tap wont turn. its one of those old T taps. its in an awkard space but i manage to hit with a hammer.. still it wont turn!!!! Is there any way to turn the bathroom cold water off or get this stop valve to turn???? help would be much appreciated.
Pakamish is offline
Old 23-06-2009   #2 (permalink)
puddle
Info
Default Re: Cold Water just wont shut down!!!!
Well if you hit it with a hammer and it still did not turn, I just don’t know, every time I hit things with my hammer they always works!! , maybe the hammer is not big enough. I find the Rothenberger hammers the best; you can add weights as required
However
Your cold in the bathroom is probably from a tank in the roof,if you let run with mains stop cock off should drain down and water will stop after a while ,then you can sort out basin and replace stop cock that will not turn
As you are living in a flat,your tank my have seperate isolation in roof and may shut other flats off,you may have to get someone in to freeze pipework and fit new isolation to allow works to continue
puddle is offline
Old 23-06-2009   #3 (permalink)
Smcart5
Info
I am puzzled, if the system is indirect then it would explain why his cold tap in the bathroom does not switch off after shutting off the mains, he's emptying the cwsc, which would take a while and give the illusion of a faulty stoptap...
Edit, puddle-if his valve under the sink turned off both his hot and cold water wouldn't that mean his system is direct and would not have a separate storage tank, , the cold still flowing in the bathroom but not the hot, and the kitchen taps both off from one valve puzzles me
Smcart5 is offline
Old 23-06-2009   #4 (permalink)
REDSAW34
REDSAW34's Avatar
Info
you may find this guy, (other than getting in a plumber) could give you a few tricks especially with the hammer.
REDSAW34 is offline
Old 24-06-2009   #5 (permalink)
Pakamish
Info
Puddle, I see my hammer hitting has amused to.. ill be sure to get a sledge hammer next time. to go back to you point regarding the tank. Im pretty sure there arent any tanks. There is only on flat above me and its roof is too narrow. Say for instance you are correct and i let the water ran while turning off the mains. How long will it take before the cold water stops flowing? Also is there some stop tap that can be screwed into cold water pipe while the water is running to shut it off?
Pakamish is offline
Old 24-06-2009   #6 (permalink)
dontknowitall
Info
Pakamish
A thought ... is this your flat? If not, don't assume the hot and cold are the right way round. (I've come across a hot tap (with a red marker) which was the cold and the cold tap (with a blue marker) which was the hot.) So only real way to test is run the hot and see which pipes are hot and cold.
As mentioned above it does sound as if there's a cistern somewhere. If there's an open vented hot water cylinder there will be a cistern to feed it which could be a small tank that is completely hidden and boxed in somewhere. If you've turned off the incoming supply and there is water still coming out of the taps it does mean there's a storage of water somewhere!
Rather than us guessing, if you could say:
What type of boiler (standard or combination or other?).
What's in the airing cupboard (assuming there is an airing cupboard or similar)? For example, is there an immersion heater in a hot water cylinder or is there no airing cupboard?
And presumably you have one bathroom, one kitchen and nothing else?
Knowing these things and being a flat it should be quite simple for someone to tell you what to look for.
Little tip ... next time you take a hammer to a tap, make sure you know how much water might flood out before you break the tap! In my experience taps break rather too easily!!
Hope this helps.
dontknowitall is offline
Old 24-06-2009   #7 (permalink)
traineedrip
Info
have you got any pictures of the hammer
if you open the kitchen tap full it will have a good pressure, compare that to the bathroom cold which will have little pressure (tank fed).
let it run with basin /bath cold taps open for 30mins... should be long enough.
traineedrip is offline
Old 24-06-2009   #8 (permalink)
Pakamish
Info
LOL. Ok i get it with the hammer thing now.. Knowitall. Here are the answers to your questions: Yes it is my flat on the ground floor.. The tap im referring too is in a airing cuboard (hidden) with only a small opening for the tap. I have a combi boiler. (vailant). Just one kitchen and bathroom. I can confirm that it is indeed the cold water that is running when the mains is turned off. The pressure is regular so I assume its coming from a tank like you said. are there any other ways around this besides letting the tap run for 30minutes? whould this affect other residents or is the tank only feeding my flat?
Pakamish is offline
Old 24-06-2009   #9 (permalink)
Mark Moss
Info
Send a message via Skype™ to Mark Moss
Pakamish, First of all you need to establish if the basin cold water is tank fed, this is easy. Run the basin cold tap and attempt to stop the flow of water by putting your thumb over the spout. If you can stop the flow by applying a bit of thumb pressure then your running off a tank. Otherwise if you get very wet and cant stop it then it will be mains fed.
So if its tank fed then i would suggest asking upstairs if you can pop in the loft to tie up the ball valve, then just open basin tap jump back up in loft and watch to see that the tank is emptying. Then wait.
If like alot of flats that i work in and you dont get on with your neighbour and he/she wont let you in the loft then i would like to know if you are a lease holder or free holder.
Mark Moss is offline
Old 24-06-2009   #10 (permalink)
dontknowitall
Info
It sounds as if your kitchen is supplied direct from the mains and the pipework will tee off from the mains a) to your kitchen tap and then b) to this hidden cistern.
In theory it shouldn't affect the other flats. You could drain it for 30 minutes (via that bath which is quicker) but what happens if, when you drain it, the ball valve sticks open when it fills again? This will leave you with a major problem and it happens quite frequently. If the ball valve fails you can't turn the water off, expect by going without water in the flat until the cistern is found and fixed.
Was about to type more, but Mark Moss has put up the help you need.
Of course, if all you neighbours get on well, one of them might be able to tell you how to turn the water off.
Hwlo with wold water tank overflowing philwilliams Plumbing Forum 2 13-04-2009 08:57 PM
Hot taps run cold - not the boiler, I reckon... plumb-line Plumbing Forum 4 30-03-2009 09:21 AM
gravity HW & mains CW mixer tap problem MarkB Valves & Taps 7 23-03-2009 12:51 PM
HELP! - WARM/HOT water coming from the COLD tap? 34mark@gmail.co Plumbing Forum 5 05-02-2009 07:01 PM
Hot water in cold water storage tank.... MarkH Plumbing Forum 7 28-11-2008 05:32 PM
