Results 1 to 8 of 8
Plumbing & Plumbers Forum - Hepvo valve - will it work?
Discuss Hepvo valve - will it work? in the Plumbing Forum at Plumbers Forums; I was having a problem with a foul odor coming from the 40mm waste pipe the washing machine is connected to. There is no P trap in place. Just a ...
    Plumbing Forum Contributor
    Sep 2010
    71
    Default Hepvo valve - will it work?
    I was having a problem with a foul odor coming from the 40mm waste pipe the washing machine is connected to. There is no P trap in place. Just a vertical run of about 200mm and then an angle to run horizontally into the main waste pipe.
    I picked up a Hepvo and connected it straight onto the pipe (i.e. vertically). The problem is the waste pipe is located just in behind one of the kitchen presses and I can't fully hand tighten the Hepvo compression connector. It's snug but due to the oil on the compression connector diaphragm, it can slide up and down.
    Will this suffice, as I have the washing machine outlet pipe inserted as far as it can go? Cheers.
    K
    7,210
    Default Re: Hepvo valve - will it work?
    I would have just fitted an appliance trap, cheaper than a hepvo.
  3. If You Burn It, It Can Kill You.
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,969
    do you have the hep vo fitted at the top of the pipe or halfway down?
    Sep 2010
    71
    Quote Originally Posted by steveb View Post
    At the top.
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,969
    you might still get smells if you have pushed the drain in past the seal on the hepvo. i would move it down lower tbh.
    Sep 2010
    71
    I know what you mean but I'm limited by space and access unfortunately.
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,969
    have you enough space to put a bit of pipe at the top without moving the hepvo down?
    Sep 2010
    71
    Don't think so. Even if there was it's impossible to get in to tighten the compression connectors enough. Might have to go with a standard trap and adhesive sealant for the joints.
  1. HepVo fittings
    By trigger25 in forum Plumbing Forum
    Last Post: 06-01-2012, 12:20 AM
  2. leaking rad valve, will a tighten work?
    By Werth in forum Plumbing Forum
    Last Post: 22-03-2011, 12:05 PM
  3. Replies: 6
    Last Post: 20-09-2010, 10:05 AM
  4. Shower waste trap plus hepVO?
    By telfian in forum Bathrooms, Showers and Wetrooms
    Last Post: 17-07-2009, 12:49 PM
  5. Do HepVo valves work
    By jgw1 in forum Plumbing Forum
    Last Post: 06-01-2009, 09:13 PM
hepvo valve
hepvo
hepvo trap
hepvo ukhepvo valve ukhepvo trap ukhepvo trap problems
