Results 1 to 4 of 4
Plumbing & Plumbers Forum - Plastic bath panel
Plastic bath panel
Discuss Plastic bath panel in the Plumbing Forum at Plumbers Forums; Need to fit a plastic bath panel, I know they are a right pain, have fitted a few straight ones where you are able to trim it, but this bath ...-
14-05-2012 #1Plumbing Forum Contributor
- Feb 2011
- 81
Plastic bath panel
Need to fit a plastic bath panel, I know they are a right pain, have fitted a few straight ones where you are able to trim it, but this bath is P shape, and looking at the panel I feel trimming it would be the wrong thing to do. are there any tips on getting the right height ,my idea is to put the bath in but not fix to wall, then ply and tile the floor,and then adjust bath to suite, or am I making hard work for myself.
Any better ideas would be most grateful .
Regards
14-05-2012 #2Moderator
- Feb 2010
- Alloa, Scotland
- 7,068
- 745
- Thanked 672 Times in 573 Posts
Re: Plastic bath panel
Measure the bath to sit at 530mm to the bottom of the rim, level it and sit a floor tile in place with a cutting of plywood for the floor and put the bath panel in position, add on the thickness of the tile and plywood and adjust bath height to suit. Keep it dead level though or the curved panel will be a pain.
Bathroom Design & Installation Specialists.
Over 34 years experience.
Rated People 5 Star Rating.
BY THE WAY I'M NOT COMMERCIAL. A flexible hose, gets up ma nose.
14-05-2012 #3Plumbers Arms member
- Apr 2009
- northampton
- 188
- 19
- Thanked 12 Times in 12 Posts
either do as sys3 says or 1st fix the bath then tile the floor then fit the bath to exact right height for
the panel, making sure its level.
make sure you cover up the floor for the rest of the tiling.
14-05-2012 #4Plumbing Forum Contributor
- Feb 2011
- 81
Thanks for that.
panel for bath
By gpack in forum Plumbing ForumReplies: 1Last Post: 20-01-2012, 09:41 AM -
Bath panel fitting problems
By jiffter in forum Plumbing ForumReplies: 2Last Post: 10-04-2011, 03:00 PM -
Corner bath panel
By mjt in forum Plumbing ForumReplies: 8Last Post: 18-12-2010, 10:30 PM -
1800mm bath panel in white
By fuzzy in forum Sanitary WareReplies: 9Last Post: 29-09-2010, 08:23 AM -
fitting bath & side panel
By PJL in forum Plumbing ForumReplies: 1Last Post: 18-08-2009, 08:09 AM
Cost to remove old electric...
8 Minutes Ago in Plumbing Forum
