Results 1 to 4 of 4
Plumbing & Plumbers Forum - Pan connectors
Pan connectors
Discuss Pan connectors in the Plumbing Forum at Plumbers Forums; Am moving a Toilet tomorrow the customer wants it moved along the same wall about 3 feet, so they can get a bath in, I was thinking of extending the ...
    Plumbing Forum Contributor
    81
    Default Pan connectors
    Am moving a Toilet tomorrow the customer wants it moved along the same wall about 3 feet, so they can get a bath in, I was thinking of extending the grey soil pipe and connecting with a flexible connector,reading some of the threads a few guys are not lovers of these, but I feel this is the way as I want the toilet to sit back against the wall, is there a limit on how far these flexibles should be stretched out I relies the longer they are the more flimsy they get.
    Regards
    Plumbers Arms member scotty plumber's Avatar
    Jan 2012
    581
    Default Re: Pan connectors
    I do not see any problem with flexi pan connector's as they can be very handy and i do not think that they look too bad either, little tip when fitting do not use silicone grease as it will keep sliding off especially if it is stretched. Use water instead as it will dry quicker
    system3's Avatar
    Feb 2010
    Alloa, Scotland
    7,069
    Flexible pan connectors are available in different lengths and their minimum and maximum working lengths are usually included either in the advert selling them online or in the packaging when you buy one. Don't overstretch one as they can slip off if you try this. Use a section of plastic soil pipe on the end to increase it's length without stretching it.
    Bathroom Design & Installation Specialists.
    Over 34 years experience.
    Rated People 5 Star Rating.
    BY THE WAY I'M NOT COMMERCIAL. A flexible hose, gets up ma nose.
    Mike Jackson's Avatar
    Hastings
    3,910
    You may need to support it if it's a long stretch to stop it sagging and all the Richards getting bcked up.
  1. Tap connectors
    By duffsparky in forum Plumbing Forum
    Last Post: 17-06-2011, 07:08 PM
  2. What are these connectors called
    By joe brown in forum Plumbing Forum
    Last Post: 24-05-2010, 07:52 PM
  3. Flexi tap connectors
    By adrian in forum Plumbing Forum
    Last Post: 25-11-2009, 11:50 PM
  4. Best pushfit connectors
    By hiney777 in forum Fittings & Pipes
    Last Post: 17-07-2009, 01:58 PM
  5. pan connectors?
    Last Post: 02-07-2009, 09:09 PM
is it wrong to use flexi pan connector
do long flexible pan connectors sag
pan connector minimum
flexible pan connector forum
flexible pan connecyor forum
can you use a flexible pan connector without extending
can a flexible pan connecter move a toilet
