Results 1 to 15 of 25
Plumbing & Plumbers Forum - M.I pipe flow & return what size is this ??
Discuss M.I pipe flow & return what size is this ?? in the Plumbing Forum at Plumbers Forums; Alright team, Removed an old radiator today which is being fed by M.I. pipe which looks slightly bigger than 22mm but not as much as 28mm! My question is, you ...-
09-05-2012 #1Plumbers Arms member
- Jan 2011
- Glasgow
- 854
- 55
- Thanked 38 Times in 34 Posts
Alright team,
Removed an old radiator today which is being fed by M.I. pipe which looks slightly bigger than 22mm but not as much as 28mm! My question is, you see the 2 valves are closed but the ballos are passing, I need a cap to either thread into that ballo, I tried a meter cap but it was too big!
www.McNivens.com - Plumbing, Heating, Gas, Glasgow
09-05-2012 #2UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 5,803
- 124
Re: M.I pipe flow & return what size is this ??
probably 1" if not 3/4. 7/8 was a bsp size as well.
btw im commercial, NOT.
09-05-2012 #3UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,137
- 531
- Thanked 427 Times in 362 Posts
Looks to me like a 3/4 cap would do it.
Gas, LPG, and OFTEC (oil) Registered.... visit my website at: www.prestigeplumbers.co.uk
Click to follow the link!
09-05-2012 #4UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Looks to me like a 3/4. If you want to make sure.
Have a look at the elbows. They usually have the size stamped in to them"nothing is impossible"
09-05-2012 #5Plumbers Arms member
- Jan 2011
- Glasgow
- 854
- 55
u lads r class
09-05-2012 #6Moderator
- Nov 2007
- hythe hampshire
- 8,973
- 446
- Thanked 746 Times in 726 Posts
looks like 3/4 to me as well
09-05-2012 #7Plumbers Arms member
- Jan 2011
- Glasgow
- 854
- 55
iv just never used mI, so i can just remove the ballos then and just fit a 3/4 female cap?
09-05-2012 #8UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Yes. Just unscrew.
I would recommend unscrewing the pipe from the elbow if you want to make it neater. Realistically you want to take as much pipe out as is redundant
You can just get a 3/4 plug to cap a fitting or a 3/4 cap to cap a pipe.Be sure to ptfe and not to unwind at all, unless using loctite 55.
It is tapered thread so it will get more difficult as you tighten"nothing is impossible"
09-05-2012 #9Plumbers Arms member
- Jan 2011
- Glasgow
- 854
- 55
class simon! thank you mate
09-05-2012 #10Plumbers Arms member
- Jan 2011
- Glasgow
- 854
- 55
Toolstation > Plumbing > Compression > Brass Cap
would this work ??www.McNivens.com - Plumbing, Heating, Gas, Glasgow
09-05-2012 #11UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Use this for plugging the fitting
http://www.raygrahams.com/products/1...n-plug-34.aspx
Use this for capping a pipe
http://www.builderdepot.co.uk/black-...3-4-black.html
The treads are longer and tapered"nothing is impossible"
09-05-2012 #12Plumbers Arms member
- Jan 2011
- Glasgow
- 854
- 55
Simon does any of the big brands do this so I could pick up tomorrow? The one for capping pipe!
09-05-2012 #13UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Pipe centre
Bss
Possible : plumb centre."nothing is impossible"
09-05-2012 #14Plumbers Arms member
- Jan 2011
- Glasgow
- 854
- 55
toplad Simon!
10-05-2012 #15UK Plumbersforums Trusted Advisor.
- Mar 2010
- lincolnshire
- 3,737
- 297
- Thanked 374 Times in 357 Posts
3/4" pipe has an outside dimension of approx 26.67mm and you will get a plug from all good plumbers merchants
Maximum Flow and Return Pipe Lengths for Log Burner 6M?
By Graham Land in forum Central Heating ForumReplies: 10Last Post: 07-06-2011, 08:31 PM -
Flow and Return
By MartynJM in forum Plumbing ForumReplies: 13Last Post: 09-01-2011, 12:35 AM -
Floor standing Boiler with 1 flow pipe and 2 return pipes leading into it
By quattro64 in forum Central Heating ForumReplies: 1Last Post: 08-09-2010, 10:31 PM -
suprima 30kw pipe sizing off flow and return
By Readingplumber in forum Central Heating ForumReplies: 3Last Post: 13-03-2010, 04:42 PM -
flow or return
By plumdum in forum Central Heating ForumReplies: 2Last Post: 17-01-2010, 11:58 AM
2Likes
what is it ?
43 Minutes Ago in General Off-Topic Chat
