Results 16 to 25 of 25
Plumbing & Plumbers Forum - M.I pipe flow & return what size is this ??
Discuss M.I pipe flow & return what size is this ?? in the Plumbing Forum at Plumbers Forums; black iron plugs and caps at all good plumbing merchants upto 1" ....-
10-05-2012 #16UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 5,824
- 124
Re: M.I pipe flow & return what size is this ??
btw im commercial, NOT.
10-05-2012 #17Plumbers Arms member
- Jan 2011
- Glasgow
- 855
- 55
- Thanked 38 Times in 34 Posts
can u lads get this old MI pipe turned out a fitting with just normal footprints?? its solid!! i need big stilsons maybe.
www.McNivens.com - Plumbing, Heating, Gas, Glasgow
10-05-2012 #18Plumbers Arms member
- Jan 2012
- Essex
- 3,201
- 80
Not from here I can't.
I find that heat and two pair of 12" grips usually does the trick on the stubborn fittings.Proud to be 'Part P', the world is now my mollusc!
10-05-2012 #19UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Use mapp gas onto the fitting. A 5 year old will get it out once its hot enough
"nothing is impossible"
10-05-2012 #20UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,384
- 281
- Thanked 1,179 Times in 1,046 Posts
Stilsons will get a better grip on the pipe than any other type grips. They won't slip either. A 14" set will move most things domestic.
10-05-2012 #21Plumbers Arms member
- Jan 2011
- Glasgow
- 855
- 55
toplads!!
10-05-2012 #22Plumbers Arms member
- Apr 2011
- Sheffield
- 655
- 32
- Thanked 48 Times in 47 Posts
I always keep a pair of 14" & 18" stilsons in the van. Got me out of quite a few pickles over the years! Got a pair of 24" aluminium Ridgid stillies in garage for if and still got me 36" Record ones in there somewhere (weigh more than ar lass and fortunately haven't had to use em yet!)
10-05-2012 #23UK Plumbersforums Trusted Advisor.
- Oct 2010
- Glasgow, Scotland
- 4,696
- 324
- Thanked 260 Times in 254 Posts
go to MacLean fittings for your MI stuff, down in Kinning Park
11-05-2012 #24UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,141
- 531
- Thanked 428 Times in 363 Posts
Stilsons. You can buy cheap pair 2ft long, from the market for a tenner. For the amount of time you use them, they'll do!!
Gas, LPG, and OFTEC (oil) Registered.... visit my website at: www.prestigeplumbers.co.uk
Click to follow the link!
11-05-2012 #25UK Plumbersforums Trusted Advisor.
- Apr 2009
- Tunbridge Wells
- 5,141
- 531
Should add, that as mentioned by others, you'll get away with a pair of 18" with this. I bought a decent set of 18" as they're going to get used more often.
Maximum Flow and Return Pipe Lengths for Log Burner 6M?
By Graham Land in forum Central Heating ForumReplies: 10Last Post: 07-06-2011, 08:31 PM -
Flow and Return
By MartynJM in forum Plumbing ForumReplies: 13Last Post: 09-01-2011, 12:35 AM -
Floor standing Boiler with 1 flow pipe and 2 return pipes leading into it
By quattro64 in forum Central Heating ForumReplies: 1Last Post: 08-09-2010, 10:31 PM -
suprima 30kw pipe sizing off flow and return
By Readingplumber in forum Central Heating ForumReplies: 3Last Post: 13-03-2010, 04:42 PM -
flow or return
By plumdum in forum Central Heating ForumReplies: 2Last Post: 17-01-2010, 11:58 AM
2Likes
Cold call from EMS Internet or EMS...
6 Minutes Ago in General Off-Topic Chat
