Results 1 to 9 of 9
Plumbing & Plumbers Forum - Flue clearances- gas fire
Discuss Flue clearances- gas fire in the Plumbing Forum at Plumbers Forums; Hi, I have a room sealed natural draught flue that needs to be installed vertically from the fire, terminating on a new flat roof extension, does anyone know what the ...
    May 2012
    Default Flue clearances- gas fire
    I have a room sealed natural draught flue that needs to be installed vertically from the fire, terminating on a new flat roof extension, does anyone know what the clearance should be from the flue to an openable window, also does the flue need to rise above pitched roof line? The fire is from the netherlands but is CE marked, mi's dont give any info on clearances, have scoured BS 5440 part 1 but cant find the clearances for a flat roof. Corgi book says 400mm horizontally but surely this only applies when on the same wall as the opening??
    Mike Jackson's Avatar
    Hastings
    3,903
    Default Re: Flue clearances- gas fire
    Do you have a link to the fire. I don't think I've come across a vertical natural draught balanced flue.
  3. Gas Safe Registered Engineer for all your Domestic gas, Heating and plumbing needs in Hastings, East Sussex. Check me out on the Gas Safe website, reg. No. 537192.
    diamondgas's Avatar
    Newcastle Upon tyne
    6,053
    May 2012
    here is a link to the mi's,
    many thanks
    http://www.drugasar.co.uk/pdfs/metro...tro_tunnel.pdf
    May 2012
    manchester
    873
    Try these
    Drugasar
    deans road
    swinton
    manchester
    0161 793 8700
    they are the uk part of this Dutch company.
  8. The Following User Says Thank You to stani For This Useful Post:
    Tom1980 (09-05-2012)
  9. #7
    AWheating's Avatar
    WestMidlands
    5,827
    is there any information in building regs part j?
    btw im commercial,
    NOT.
  10. #8
    Hastings
    3,903
    Quote Originally Posted by Tom1980 View Post
    many thanks
    It looks a complete nightmare to fit.
  11. #9
    May 2012
    Hi, part j states that it should be 2 metres away from an opening on a flat or pitched roof if below, the flue terminal will pretty much be in line with the middle of the sash window on the original part of the house, the terminal is 1.1 metres away from the sash window, should I treat this as a horizontal distance?? wwhich would be a minimum of 400mm for this fire
  1. fire and bbu flue through flat above
    By dave1 in forum Gas Safe Register Forum - Public Forum
    Last Post: 19-03-2012, 01:06 AM
  2. Flavel Raglan Balanced Flue Gas Fire
    By PowerFlusher2 in forum Central Heating Forum
    Last Post: 01-02-2012, 05:47 PM
  3. Gas Fire Flue?
    By theiron in forum Central Heating Forum
    Last Post: 13-02-2011, 09:23 PM
  4. ILFE Fire / Flue analyser
    By amy in forum Gas Safe Register Forum - Public Forum
    Last Post: 30-08-2010, 04:50 PM
gas safe flue flat roof
gas flue clearances for extension
dru metro fire installation
roof clearance for gas fire flue
clearance distance for gas fires
gas fire flue distance windows
dru gas fire forum
