Results 1 to 9 of 9
Plumbing & Plumbers Forum - hi can you help
hi can you help
Discuss hi can you help in the Plumbing Forum at Plumbers Forums; Hi working on a new build fitting new heating 14 rads going to run 22mm speed fit for flow and return walls will be dot and dabed so was thinking ...-
07-05-2012 #1New to Plumbing Forum
- May 2012
hi can you help
Hi working on a new build fitting new heating 14 rads going to run 22mm speed fit for flow and return walls will be dot and dabed so was thinking of using 10mm speed fit for will it be ok
Last edited by jim4; 08-05-2012 at 03:33 AM. Reason: new on computer and spelling is bad
07-05-2012 #2Plumbing Forum Contributor
- Nov 2009
- 46
- 5
Think you should be doin the run in 22mm at a minimum for flow and return
07-05-2012 #3Plumbers Arms member
- Jan 2010
- Glasgow
- 162
- Thanked 13 Times in 13 Posts
Re: hi can you help
I have never seen any 20mm plastic that is new.
it will leak with those seep fit fittings.
07-05-2012 #4Plumbers Arms member
- Jan 2012
- Essex
- 3,194
- 80
Copper with soldered joints for me, anything less is a diy bodge IMHO.
07-05-2012 #5
07-05-2012 #6UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
I would suggest that you get a local engineer in to aid you in your new build
You can put all the plumbing in but get a gas safe to do the boiler
I would suggest putting as much 28mm pipe in as you can and then go to 10 for the rads
Also it may work out cost effective to have the plumber do the heating for you as the discount they will get will be far greater than you could get and they will get it right first time. Also your home insurance may need to be consulted if your going to DIY the heating pipes"nothing is impossible"
07-05-2012 #7UK Plumbersforums Trusted Advisor.
- Nov 2011
- Beautiful Barlick
- 5,360
- 291
- Thanked 378 Times in 372 Posts
Re: hi can you help
is the op from abroad ? they do use 20mm there
I'M DANCIN, YOU ASKIN ?
09-05-2012 #8New to Plumbing Forum
- Apr 2012
- 16
- Thanked 1 Time in 1 Post
Re: hi can you help
Really? Never heard of that beforeAlso your home insurance may need to be consulted if your going to DIY the heating pipes
09-05-2012 #9UK Plumbersforums Trusted Advisor.
- Dec 2010
- WestMidlands
- 5,777
- 124
- Thanked 571 Times in 545 Posts
Re: hi can you help
as a general rule:
22mm speedfit will do around 13kw (11 degree difference)of rads unless its really long runs.
10mm will do about 1.8kw with a max run of 10m (5m flow,5m return)
plastic is fine to use, not a diy bodge if its installed correctly. Follow the manufactures instructions and you will be fine.
you will need to trace tape behind the 10mm drops also, and pressure test as speedfit requirements.
also clipping is very important, every 300mm is recommended every 500mm is pushing it.Last edited by AWheating; 09-05-2012 at 08:22 PM.
btw im commercial, NOT.
6Likes
Incompetent Plumber and SNIPEF
