Results 1 to 4 of 4
Plumbing & Plumbers Forum - 3 inch plastic pipe
3 inch plastic pipe
Discuss 3 inch plastic pipe in the Plumbing Forum at Plumbers Forums; Hi all,looking to replace a broken 3 inch cast pipe with 3 inch plastic pipe,but cant seem to locate any.. Anyone know where i could get some and a fitting ...-
04-05-2012 #1New to Plumbing Forum
- May 2012
3 inch plastic pipe
Anyone know where i could get some and a fitting to join them..possibly just a meter long.Cheers.
04-05-2012 #2Plumbers Arms member
- Jan 2012
- Essex
- 3,321
- 83
- Thanked 253 Times in 248 Posts
No problem.
Most decent plumbing shops will be able to get you what you want.
Pipe will have to be a three or four meter length though.
05-05-2012 #3Guest123Guest
Re: 3 inch plastic pipe
About 20 years ago, 3" soil pipe was commonly used and was cheap to buy. Unfortunately due to lack of demand these days, it has become very expensive and far more expensive than the larger 4" pipe.
Drain/Plumb Center sell it as will most major plumbers merchants.....but wait to be shocked at the price!
Ask about Timesaver, which is an easy to fit cast iron coupling and will last longer than plastic. A small section of cast iron pipe could be sourced from a local scrap metal dealer.
05-05-2012 #4Plumbers Arms member
- Jan 2012
- South coast
- 188
- 23
- Thanked 9 Times in 9 Posts
I had a thread on 3 inch last month I ended up getting the pipe itself from drain centre
Sent from my GT-I9100 using Tapatalk 2An optimist see's the glass as half full
A pessimist see's the glass as half empty
An engineer see's the glass as 50% oversized
1 inch pipe-hell
By dirtywalsh in forum Valves & TapsReplies: 22Last Post: 10-11-2011, 07:46 PM -
Plastic pipe verus copper pipe
By mark_mc in forum Plumbing ForumReplies: 35Last Post: 06-07-2011, 11:15 AM -
What type of 1-1/4 to 2 inch flexible pipe to use ?
By Giles in forum Plumbing ForumReplies: 5Last Post: 21-02-2010, 09:06 AM -
one inch brit to one inch american
By ijon in forum Plumbing ForumReplies: 2Last Post: 28-07-2009, 05:59 PM
SIAMP Skipper 45 Flush Problem
