Results 1 to 12 of 21
Plumbing & Plumbers Forum - gas leak head scratch!!
Discuss gas leak head scratch!! in the Plumbing Forum at Plumbers Forums; anyone else had this?? done a tightness test. there is a small drop. isolate appliences and when i get to the boiler and isolate it, it stops dropping. so iv ...-
02-05-2012 #1Steady Plumbing Forum Contributor
- Jun 2011
- oldham
- 147
- Thanked 9 Times in 9 Posts
anyone else had this?? done a tightness test. there is a small drop. isolate appliences and when i get to the boiler and isolate it, it stops dropping. so iv found the culprite. open the valve again just to see it drop again for confirmation and its all ok???? probably re-greased itself or something, but it makes you paranoid then!! haha
02-05-2012 #2Moderator
- Nov 2009
- THE BEST COUNTY IN THE LAND - YORKSHIRE
- 10,789
- 474
- Thanked 562 Times in 518 Posts
Re: gas leak head scratch!!
so leak is on boiler
02-05-2012 #3Steady Plumbing Forum Contributor
- Jun 2011
- oldham
- 147
it was, then when i reopened the valve there was no leak anymore? crazy! did it a few times just to check but nothin. wierd! iv had it before with an ECV letting by. i turned the ECV on then off again and no more let by.
02-05-2012 #4Moderator
- Nov 2009
- 10,789
- 474
had it on a valve
02-05-2012 #5Steady Plumbing Forum Contributor
- Jun 2011
- oldham
- 147
i know it happens but it makes you scratch your head!! like you imagined it or something!
02-05-2012 #6Moderator
- Nov 2009
- 10,789
- 474
best way to be , accidents can happen when we get complacent
02-05-2012 #7UK Plumbersforums Trusted Advisor.
- Oct 2010
- Northampton
- 6,224
- 625
- Thanked 295 Times in 285 Posts
only posible if pipes are still hot , never do tt when pipes are hot !
02-05-2012 #8Top Plumbing Forum Contributor
- Aug 2011
- Wolverhampton
- 724
- Thanked 50 Times in 48 Posts
Had this before too. Pain gas leaks are, I hate them when you can't fine the little bleeders!
02-05-2012 #9Moderator
- Nov 2009
- 10,789
- 474
best thing i did was getting the sniffer for my fga , zaps battery mind
02-05-2012 #10UK Plumbersforums Trusted Advisor.
- Hastings
- 4,023
- 47
- Thanked 405 Times in 375 Posts
I've had it where the pilot hadn't shut off properly on a boiler. Whenisolatedit sorted itself.
Sent from my iPad using Tapatalk HDGas Safe Registered Engineer for all your Domestic gas, Heating and plumbing needs in Hastings, East Sussex. Check me out on the Gas Safe website, reg. No. 537192.
02-05-2012 #11Steady Plumbing Forum Contributor
- Jun 2011
- oldham
- 147
thats pretty obvious, but not only possible if pipes are hot. theres quite a few situations this can happen. slight tear in monometer tube at the end, then when you push it on past the tear it stops. (this would obviously get noticed eventually and rectified) or like mike jackson says with a pilot. even tempremental solanoids. etc etc
02-05-2012 #12Moderator
- Nov 2009
- 10,789
- 474
paint
Scratch Chrome
By whamo in forum Plumbing ForumReplies: 5Last Post: 17-11-2011, 05:21 PM -
one for gas man, leak from a 105e pressure diff head.
By moogwai in forum Central Heating ForumReplies: 6Last Post: 21-07-2011, 01:00 AM -
starting a career in plumbing from scratch...would love advice please!
By jonoratner in forum Plumbing Courses FeedbackReplies: 4Last Post: 11-11-2010, 09:28 PM -
Is This Up To Scratch?
By acvc in forum Plumbing ForumReplies: 8Last Post: 16-09-2010, 12:42 PM -
You scratch my back and i'll scratch yours
By WANNABEPLUMBER in forum Plumbing ForumReplies: 4Last Post: 29-01-2009, 07:32 PM
7Likes
2 Hours Ago in Plumbing Tools
