Plumbing & Plumbers Forum - Back boiler cylinder removal
Discuss Back boiler cylinder removal in the Plumbing Forum at Plumbers Forums; I have a solid fuel burning back boiler in my front room which heats the rads and one tap which no longer gets used as i have a combi boiler ...
    Misswomy
    Default Back boiler cylinder removal
    I have a solid fuel burning back boiler in my front room which heats the rads and one tap which no longer gets used as i have a combi boiler for all my hot water and other rads that i had added. I would like to remove the old cylinder but keep the back boiler for the radiators...is this possible?
    Apr 2009
    231
    Default Re: Back boiler cylinder removal
    My first thought is the back boiler would have too much heat to be able to dissipate it through a couple of rads consequently the water would boil,
    Aug 2008
    1,529
    Hi. Bob's comments are correct. Gravity circulation requires far larger dia. pipes and far more detail on design, in relation to pumped systems. The cylinder you removed would have been on a gravity circuit (28 mm pipes) the rads you mention may well be on a small pumped circuit. With solid fuel boilers control of the heat produced can not be controlled instantly as with say gas. In the event of the circulating pump failing due to a fault or power failure the water would not circulate quick enough to disipate heat and the system would boil, creating a dangerous situation in your home.
  1. disconect solid fuel back boiler
    By spencer in forum Plumbing Forum
    Last Post: 06-11-2009, 05:09 PM
  2. Some expert advice needed - Back Boiler
    By Paul591 in forum Central Heating Forum
    Last Post: 06-04-2009, 09:56 AM
  3. baxi back boiler
    By phlebo1 in forum Central Heating Forum
    Last Post: 26-02-2009, 10:00 AM
  4. indirect cylinder heated by back burner
    By nick penfold in forum Central Heating Forum
    Last Post: 18-12-2008, 09:19 PM
removing back boiler
how to remove solid fuel back boiler
safe removeal of a solid fuel back boiler
how to remove back boiler
removing a back boiler
how to remove a back boiler
