Results 1 to 4 of 4
Plumbing & Plumbers Forum - Noisy pump
Noisy pump
Discuss Noisy pump in the Plumbing Forum at Plumbers Forums; Grundfos Bronze 15-50. Noisy pump on secondary return. 15 mm into and out of the pump. should this pump run constantly? Should the pipework be increased? What would cause it ...-
16-06-2009 #1New to Plumbing Forum
- Mar 2009
- 6
Noisy pump
Grundfos Bronze 15-50. Noisy pump on secondary return. 15 mm into and out of the pump. should this pump run constantly? Should the pipework be increased? What would cause it to be noisy?
17-06-2009 #2UK Plumbersforums Trusted Advisor.
- Hastings
- 4,023
- 47
- Thanked 405 Times in 375 Posts
Re: Noisy pump
15mm is fine. Try turning the speed down. I like to time secondary pumps so they don't run overnight. It may be the bearings on the way out.
18-06-2009 #3New to Plumbing Forum
- Jun 2009
- Knowsley, Liverpool
- 17
- Thanked 1 Time in 1 Post
21-06-2009 #4royalflushGuest
Re: Noisy pump
It's had its day, change it.
URGENT HELP - Grunfos water pump
By phozy888 in forum Bathrooms, Showers and WetroomsReplies: 12Last Post: 12-01-2010, 12:29 PM -
badly fiited pump
By deano76 in forum Plumbing ForumReplies: 5Last Post: 25-03-2009, 07:24 AM -
Separate pump in addition to the one included in the condensing boiler?
By hughs in forum Central Heating ForumReplies: 11Last Post: 10-02-2009, 06:28 PM -
wilo pump problem
By buffy27 in forum Plumbing ForumReplies: 3Last Post: 15-01-2009, 09:02 PM -
shower pump problems!!!
By obseen16 in forum Plumbing ForumReplies: 10Last Post: 10-01-2009, 04:03 PM
46 Minutes Ago in Plumbing Tools
