Plumbing & Plumbers Forum - Hot Cylinder To be or not to be... (Replaced)?
Discuss Hot Cylinder To be or not to be... (Replaced)? in the Plumbing Forum at Plumbers Forums; Hi Guys I'm getting ready to install a shower pump into my house. Question is: The hot water cylinder is approximatley 28 years old, and although we've never had an ...-
07-02-2012 #1New to Plumbing Forum
- Jan 2012
- 20
- 29
- Thanked 2 Times in 2 Posts
Hi Guys
Question is: The hot water cylinder is approximatley 28 years old, and although we've never had an issue with it would you change it?
Regards
Blu
07-02-2012 #2Moderator
- Nov 2007
- hythe hampshire
- 8,983
- 447
- Thanked 747 Times in 727 Posts
Re: Hot Cylinder To be or not to be... (Replaced)?
not if it doesn't leak and it is still doing what it is supposed to. presumably you have it well lagged
the only problem you may have is if you are in a hard water area then it will probably be scaled up
The Following User Says Thank You to steveb For This Useful Post:
DIYBlues (07-02-2012)
07-02-2012 #3
i saw a toilet cistern today which had accumulated so much scale it took up a third of the space in slates of the stuff. it had been going down the flush pipe and getting stuck causing it to leak. dread to think how much a cylinder could build up in 28 years. i've heard of people not being able to lift them because the scale is so heavy.
*brilliant signature*
The Following User Says Thank You to WaterTight For This Useful Post:
07-02-2012 #4New to Plumbing Forum
- Jan 2012
- 20
- 29
Definitely a hard water area
07-02-2012 #5Moderator
- Nov 2007
- hythe hampshire
- 8,983
- 447
then i would say that it would be a good idea with a cylinder of such vintage that it would be a good idea to change it
DIYBlues (08-02-2012)
07-02-2012 #6UK Plumbersforums Trusted Advisor.
- Nov 2011
- Nottingham
- 1,428
- 64
- Thanked 284 Times in 276 Posts
as you are fitting a shower pump you will need to work on the cylinder to suit with a flange of some type.
so if its not leaking now it could well be when your finished.
if you go for a new cylinder try and get one with the shower connection already fitted
The Following User Says Thank You to Simon F For This Useful Post:
08-02-2012 #7New to Plumbing Forum
- Jan 2012
- 20
- 29
Thanks Simon.
Already bought a Stuart Flange to go with me Stuart and Turner Pump!
Someone mentioned that the tank could tear taking the old one out!!
Baxi 105e PCB replaced. What now?
By Apas in forum Central Heating ForumReplies: 18Last Post: 01-06-2011, 07:58 PM -
Is ACS being replaced??????
By psk in forum Gas Safe Register Forum - Public ForumReplies: 22Last Post: 29-11-2010, 09:17 PM -
3 way valve replaced and not working
By Sime in forum Central Heating ForumReplies: 3Last Post: 22-09-2010, 04:06 PM -
Help Please? Decommissioning a bath to be replaced.
By mutley racers in forum Plumbing ForumReplies: 5Last Post: 05-02-2010, 07:12 PM -
replaced three port valve
By cherryb in forum Central Heating ForumReplies: 3Last Post: 29-09-2008, 09:52 AM
plugging up drain pipes
8 Minutes Ago in Plumbing Forum
