Results 1 to 15 of 28
Plumbing & Plumbers Forum - Was there ever such a thing as a soldered stopcock?
Like Tree7Likes
Discuss Was there ever such a thing as a soldered stopcock? in the Plumbing Forum at Plumbers Forums; I've lost my camera so couldn't take a pic. It's seized and awkward so am fitting another one in line and leaving it be but it looks to me like ...
    Apr 2009
    2,686
    Default Was there ever such a thing as a soldered stopcock?
    I've lost my camera so couldn't take a pic. It's seized and awkward so am fitting another one in line and leaving it be but it looks to me like the copper pipes on both sides are soldered onto the body of the stopcock. There are no nuts, just smooth rounded surface. The 15mm copper pipe sort of flares outwards as it joins the body of the stop cock where it seems to then become the body of the stopcock. The whole arrangement was painted so couldn't see 100% clearly but was very lightly and thinly painted and so I could see there were definetly no nuts, nothing with sides to fit a spanner on and pipes were copper, definetly not lead.
  2. *brilliant signature*
  3. #2
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,738
    Default Re: Was there ever such a thing as a soldered stopcock?
    Yes there was and you can still get them
  4. >>>>>>>>>I'M ASKIN, YOU DANCIN<<<<<<<<
  5. The Following User Says Thank You to ecowarm For This Useful Post:
    WaterTight (06-02-2012)
  6. #3
    Apr 2009
    2,686
    Hmm. Ok, cheers. At least I'm not going crazy. I did google it and checked on BES (which seems to have most oddities) first but didn't see anything so thought maybe I imagined it.
  7. #4
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,738
  8. The Following User Says Thank You to ecowarm For This Useful Post:
    scotty plumber (06-02-2012)
  9. #5
    Apr 2009
    2,686
    Ahha. Kind of unprofessional to have fitted one of these on top of half an inch of pipe popping out of a concrete floor at the back of a toilet though. Luckily I've room to fit another one inline.
  10. #6
    Jan 2008
    North Yorkshire
    4,150
    Yes, you can get brass end feed ones too.
    Came acoss one a while back where someone had soldered it on without taking out the tap mechanism. The washers had melted and gummed up the workings so it didnt shut.
  11. #7
    ecowarm's Avatar
    Mar 2010
    lincolnshire
    3,738
    just rewasher it?
  12. #8
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,979
    you could take a normal stop cock and swap the workings over they look like the same size 71816.jpgSRIYP50115.jpg
  13. #9
    Plumbers Arms member scotty plumber's Avatar
    Jan 2012
    581
    I never knew that you could get these
  14. #10
    Aug 2010
    425
    They used to be all you could get. I bet plumbers of the time looked down at compression fittings like we do with pushfit
    system3, kirkgas, steveb and 1 others like this.
  15. #11
    Mike Jackson's Avatar
    Hastings
    3,895
    Pah modern rubbish. What you want is a good old brass stop tap with the tails to wipe a lead joint onto. Modern copper stuff isn't a patch on lead.
  16. #12
    Apr 2009
    2,686
    i thought of just changing the innards over but it looks properly old and i doubted i'd find a good match. doesn't look like the one pictured or any i've installed - it had virtually no detail/shapes/gumph. was just a spindle coming out of a plate. i seem to remember being told by a bloke in the merchants that you can't get matching innards for all old stop cocks types. best left alone i reckoned.
  17. #13
    system3's Avatar
    Feb 2010
    Alloa, Scotland
    7,068
    Sometimes I wish that there was a self cutting valve that sliced through the whole pipe and clamped it and isolated the water supply, and I don't mean those horrible washing machine things! Would be good for emergencies.
  18. #14
    APPlumbing's Avatar
    Locks Heath fareham
    3,165
    Quote Originally Posted by system3 View Post
    Sounds like an idea for dragons den mate. I'd buy one for a start!
    system3 likes this.
  19. #15
    Nat
    Nat is offline
    Jan 2011
    brighton area
    376
    While we are on the subject of stopcocks is it ok to have a lever ARM stopcock in place of a normal type as a main stopcock into a house? Why do people bother with the other type anyway I much prefer the quarter turn valves? Is it a reliability thing?
  1. Young thing of the year
    By SimonJohns in forum General Off-Topic Chat
    Last Post: 30-01-2012, 06:16 PM
  2. most common thing said
    By jackyp1234 in forum Plumbing Forum
    Last Post: 17-01-2012, 10:35 PM
  3. its a blonde thing
    By gas man in forum General Off-Topic Chat
    Last Post: 02-12-2011, 05:54 PM
  4. first soldered joint.
    By Joe shmoe in forum Plumbing Forum
    Last Post: 06-04-2010, 08:15 AM
  5. soldered tee
    By jimstow in forum Plumbing Forum
    Last Post: 21-03-2010, 10:58 PM
stopcock soldered joint
solder stop cock
soldered gas stop cock
self cutting stopcock
self cutting stop cock
what size is a solder stopcock
stopcock solder
