Plumbing & Plumbers Forum - Showers?
Showers?
Discuss Showers? in the Plumbing Forum at Plumbers Forums; Hi all.. im shortly going to be refurbing my bathroom.it currently does not have a shower. my hot water is fed from a communal boiler. and cold water of a ...-
20-01-2012 #1New to Plumbing Forum
- May 2011
- 4
Showers?
Hi all.. im shortly going to be refurbing my bathroom.it currently does not have a shower. my hot water is fed from a communal boiler. and cold water of a tank in my flat. what do you suggest the best shower to fit is? and also if running the pipes from under the bath up to the shower on a block wall..whats the best way to do this? cheers in advance
20-01-2012 #2UK Plumbersforums Trusted Advisor.
- Nov 2011
- Nottingham
- 1,416
- 63
- Thanked 279 Times in 271 Posts
Re: Showers?
is the hot water instantaneous and at a higher pressure or from a tank?
20-01-2012 #3New to Plumbing Forum
- May 2011
- 4
Re: Showers?
yeh the hot water is instantaneous and at reasonably good pressure.. cheers
20-01-2012 #4UK Plumbersforums Trusted Advisor.
- Nov 2011
- Nottingham
- 1,416
- 63
Re: Showers?
do you pay for the hot water you use or not? if its free to you then naturally you would want to take advantage of that.
the issue you have is different water pressures.
20-01-2012 #5New to Plumbing Forum
- May 2011
- 4
Re: Showers?
i also have communal oil heating at a charge every year for oil.so i assume this would also cover the hot water. do you think a power shower would work ok?
showers
By WaterTight in forum Plumbing ForumReplies: 3Last Post: 26-06-2010, 05:53 PM -
New showers
By mrplumber in forum Bathrooms, Showers and WetroomsReplies: 5Last Post: 16-11-2009, 03:53 PM -
showers again
By wessie in forum Bathrooms, Showers and WetroomsReplies: 2Last Post: 07-06-2008, 10:49 PM -
Gym showers
By markfxy in forum Plumbing ForumReplies: 2Last Post: 04-02-2008, 08:39 PM
Mixer Tap Cartridge Removal - It...
4 Minutes Ago in Plumbing Forum
