Results 1 to 11 of 11
Plumbing & Plumbers Forum - Radiators won't turn off
Discuss Radiators won't turn off at UK Plumbers Forums; Grateful if someone could help with this (probably very basic) problem. I have two of my radiators turned to 'off' yet when the heating is on, they both pump out ...
    Aug 2011
    Default Radiators won't turn off
    Grateful if someone could help with this (probably very basic) problem. I have two of my radiators turned to 'off' yet when the heating is on, they both pump out heat full blast. Other radiators in the house stay off when turned to this setting- any ideas why this might be happening?
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,930
    Default Re: Radiators won't turn off
    are you turning the rads off by using the trvs?
    The Turtle Moves
    Aug 2011
    Sorry, not sure what trvs is? I'm using the valve on the side of the radiator.
    Super Moderator
    steveb's Avatar
    Nov 2007
    hythe hampshire
    12,930
    trv=thermostatic radiator valve (big white lump on rad valve). are you turning feed or return off? sounds like valve is not turned off enough and still letting by.
    The Turtle Moves
    Aug 2011
    Yes, I am using the trv- on both radiators, they're turned as far as possible (tightly too) onto the 'off' position. I have other radiators in the house on this position and they remain off.
    Simon F's Avatar
    Nottingham
    2,211
    sounds like the head of the valve is bust, to test take the head of, is there any resistance and movement on the rod inside when turned. easy test swap for one of the trv heads that you know works.
    stevetheplumber's Avatar
    east london
    10,613
    you shouldnt realy be turning of rads using the trvs your room stat is the thing to use
    Howsie's Avatar
    Surrey
    5,208
    Why not? This is what they are for.
    Unregistered
    Just wondered if you ever got to the root of the problem on this one? I have the exact same problem on two radiators in my house now and not sure what to do
    Member Matchless.plumb's Avatar
    Sep 2015
    867
    As mentioned previously either rod is Jamed or washer is warned out and it still lets by even though you turned off or room thermostat isn't settled
    east london
    10,613
    Quote Originally Posted by Howsie View Post
    leaving trvs shut down is what causes them to stick ive found ideally they should be set for comfort and left alone turning the stat down or switching of at programmer is the best way to stop system when not in use
    obviously in this case they need replacing
  1. turn up boiler or turn up radiator ?
    By mickey's mum in forum Central Heating Forum
    Last Post: 14-02-2013, 08:00 PM
  2. Why don't my Gas Central Heating Radiators turn on?
    By justwannab in forum Central Heating Forum
    Last Post: 19-10-2011, 08:57 AM
  3. Radiators Wont Turn Off
    By chris34720 in forum Central Heating Forum
    Last Post: 04-04-2011, 03:35 PM
  4. Help! Can't turn it off!!
    By Clouseau in forum Central Heating Forum
    Last Post: 05-02-2011, 10:48 AM
  5. Replies: 14
    Last Post: 08-12-2010, 08:12 PM
  6. Outside tap won't turn off
    By lydia858512 in forum Plumbing Forum
    Last Post: 17-05-2010, 05:37 PM
  7. downstairs radiators turn off when upstairs are on and Vice Versa
    By ghoyland in forum Central Heating Forum
    Last Post: 12-01-2010, 08:10 PM
  8. nothing unless you turn on the tap?
    By shepster in forum Bathrooms, Showers and Wetrooms
    Last Post: 14-07-2009, 10:03 AM
  9. Hot tap won't turn off
    By sibs in forum Valves & Taps
    Last Post: 10-11-2008, 01:52 AM
radiator wont turn off
my radiator wont turn off
radiators wont turn off
radiator valve wont turn offcant turn radiator off
