Results 49 to 60 of 80
Plumbing & Plumbers Forum - Newly installed combi losing pressure
Discuss Newly installed combi losing pressure in the Plumbing Forum at Plumbers Forums; Originally Posted by APPlumbing Have a large drink and sit in a darkened room. It could've been worse. Could've been a leak upstairs and the ceiling could've been down. Every ...-
12-01-2012 #49New to Plumbing Forum
- Jan 2012
- 27
- 7
12-01-2012 #50New to Plumbing Forum
- Jan 2012
- 27
- 7
12-01-2012 #51UK Plumbersforums Trusted Advisor.
- Oct 2010
- Glasgow, Scotland
- 4,701
- 324
- Thanked 260 Times in 254 Posts
Re: Newly installed combi losing pressure
don't worry all plumbers take scrap, they dont leave ferminting kebabs though...:P
Plumbing & Heating Engineer
12-01-2012 #52
12-01-2012 #53UK Plumbersforums Trusted Advisor.
- Oct 2010
- Glasgow, Scotland
- 4,701
- 324
the last customer that wanted to keep the scrap got to keep the radiators, i was up in the loft cutting out the old primatic cylinder and he's like "don't worry I'll get that" always hovering around like a vulture
explained to him that its part of the job but i was happy for him to keep the rads:PPlumbing & Heating Engineer
12-01-2012 #54Plumbers Arms member
- Apr 2008
- West Yorkshire
- 2,051
- 233
- Thanked 102 Times in 98 Posts
What flooring was down again? Laminate?
12-01-2012 #55New to Plumbing Forum
- Jan 2012
- 27
- 7
12-01-2012 #56Plumbers Arms member
- Feb 2011
- 7,504
- 287
- Thanked 714 Times in 704 Posts
It's one of them discussions where you only get to hear one side of the argument. In my opinion its unreasonable to expect original plumber to repair at own cost or for a reduced price. Yes he should have mentioned potential problems in swapping from vented to sealed system. But at the end of the day he has done his job as per estimate, and is the reason why I have a line on my estimates which states I do not gaurantee watertightness of any existing pipework and fittings. Prevents a lot of unpleasantness.
Hopefully you will get sorted without too much mess and disruption.Fly Me To The Moon And Let Me Play Among The Stars...............
12-01-2012 #57Plumbers Arms member
- Apr 2008
- West Yorkshire
- 2,051
- 233
Its hard to picture your house or how much depth is under the floor, but I would first definatly prove the leak is in the downstairs pipes by getting him back to lock off the boiler and upstairs, if the pressure still drops then its definatly there.
I would pick an area like under a sofa or dining room tabe and make an access hatch to allow someone to get under the floor with a torch.
If you're unlucky then the depth will be too shallow to even get under, if you're very lucky then you could crawl under the whole ground floor.
12-01-2012 #58Plumbers Arms member
- Apr 2008
- West Yorkshire
- 2,051
- 233
As soon as the plumber walked through the door and saw the dreaded laminate, any sane person would have mentioned the risk straight away.
These guys get all they deserve, what would he have done if the domestic hot water pipe burst 'somewhere' under the downstairs floor?
12-01-2012 #59Plumbers Arms member
- Apr 2008
- West Yorkshire
- 2,051
- 233
My worry is the leak is under that concrete screed floor in the bathroom, probably tiled over aswell with pipes not protected against the corrosive cement.
Or there's a nail or screw through a pipe with a constant drip.
12-01-2012 #60New to Plumbing Forum
- Jan 2012
- 27
- 7
Is there a way of temporarily taking the bathroom system out of the equation and seeing if the pressure loss still occurs? The boiler is located right next to the bathroom. For me, if the leak was happening there this would be a best-case scenario as a new pipe could just be run through the wall rather than having our flooring pulled up.
Newly installed Boiler. Ideal 12
By sarah1 in forum Central Heating ForumReplies: 10Last Post: 11-10-2011, 10:35 PM -
Combi losing pressure
By Mrast in forum Central Heating ForumReplies: 7Last Post: 01-09-2011, 07:39 PM -
cold rad on newly installed system,
By ljgarrett in forum Plumbing ForumReplies: 1Last Post: 28-01-2010, 07:20 PM -
noisy newly installed Main 30HE
By Nomag in forum Plumbing ForumReplies: 6Last Post: 11-12-2008, 09:31 PM
14Likes
SIAMP Skipper 45 Flush Problem
9 Minutes Ago in Plumbing Forum
