Results 1 to 12 of 64
Plumbing & Plumbers Forum - Bending 28mm
Bending 28mm
Discuss Bending 28mm in the Plumbing Forum at Plumbers Forums; Hi all, does anybody know the ways to bend 28mm copper, is it only using hilton pipe bender stands or is there another way, mechanical/ hydraulic?...-
24-12-2011 #1
Bending 28mm
24-12-2011 #2UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
You can use a hydraulic bender. But for long term I would invest in a floor standing bender
"nothing is impossible"
24-12-2011 #3
Re: Bending 28mm
yeah but £400? thats a lot of money
24-12-2011 #4UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
Not if your buying alot of fittings or paying rent on a hydraulic bender
24-12-2011 #5UK Plumbersforums Trusted Advisor.
- Jun 2010
- Northern Ireland
- 4,873
- 76
- Thanked 447 Times in 434 Posts
I use mine most of the time don't like hand benders only for small stuff like cylinder ect
24-12-2011 #6
Re: Bending 28mm
24-12-2011 #7UK Plumbersforums Trusted Advisor.
- Dec 2010
- Bridgend, Wales
- 3,609
- 69
24-12-2011 #8Top Plumbing Forum Contributor
- Oct 2011
- Halesowen, West Mid's
- 567
- 4
- Thanked 29 Times in 29 Posts
Re: Bending 28mm
If you hurry up santa might bring you one.
.........Go on give it a click, you know you want to.........
>>>>>>>www.halesowen-plumber.co.uk<<<<<<<
24-12-2011 #9
24-12-2011 #10Plumbers Arms member
- Apr 2008
- West Yorkshire
- 2,051
- 233
- Thanked 102 Times in 98 Posts
Re: Bending 28mm
Monument 833E Internal Copper Pipe Bending Spring 28mm - Transtools
You can buy a 28mm bending spring so I assume if you anneal it you can bend it, although never tried it.
24-12-2011 #11Steady Plumbing Forum Contributor
- Apr 2010
- 125
- 3
- Thanked 6 Times in 6 Posts
Re: Bending 28mm
Just buy some 45's Fittings
24-12-2011 #12UK Plumbersforums Trusted Advisor.
- Apr 2010
- Scotland
- 9,565
- 281
- Thanked 1,206 Times in 1,073 Posts
Re: Bending 28mm
Jase Buy a 2nd hand one from ebay or wherever. These things never go wrong or wear out. Just make sure you get a full set of guides and wheels and the stop is there (you can buy spares but they are expensive). If the wheels are a bit hashed and marked rub them down smooth with wet and dry paper. Same with the guides.
Clean the threads on the handle and give it an oil (3 in 1 or similar not wd40) give it a coat of yellow paint and it will be like brand new. I have 4 stand up machines that do up to 1 1/2". They were all given to me and are probably 40 - 50 years old. They all still work perfectly and do better bends than any hand bender.
28mm SDS plus drill bit?
By capitanpugwash in forum Plumbing ToolsReplies: 11Last Post: 13-04-2011, 05:00 PM -
28mm gas meter union
By chelsea in forum Gas Safe Register Forum - Public ForumReplies: 1Last Post: 15-08-2010, 02:21 PM -
28mm Bender
By Triffid grower in forum Plumbing ToolsReplies: 19Last Post: 02-06-2010, 02:58 PM -
28mm End Caps
By Berne in forum Fittings & PipesReplies: 13Last Post: 25-03-2009, 11:43 AM
13Likes
46 Minutes Ago in Plumbing Tools
