Plumbing & Plumbers Forum - One external stop cock for three houses.
Discuss One external stop cock for three houses. in the Plumbing Forum at Plumbers Forums; Did a job in a funny little road with lots of little town houses which look like mini cottages. Couldn't find internal stop cock. There were 3 external ones in ...-
20-12-2011 #1
Did a job in a funny little road with lots of little town houses which look like mini cottages. Couldn't find internal stop cock. There were 3 external ones in a road of 7 or 8 houses. The one that turned off her water was at the end of the row, past another two houses which it presumably also turned off. I guess the houses could have been split up into separate buildings since the water supplies were run - but doesn't really look like it to me.
I wasn't sure what she should do so I told her to look everywhere she could for her internal stop cock and phone up water authority and enquire about why she doesn't have an external one but I'm guessing they may say the responsibility (cost) of having an external one installed lies with her? Do you have a right to one or is it more a case of if a house has been turned into two then it's the developer's responsibility to pay?
*brilliant signature*
20-12-2011 #2Plumbers Arms member
- May 2011
- Somerset
- 304
- Thanked 16 Times in 15 Posts
Re: One external stop cock for three houses.
It was the norm back in the day for one supply to multiple properties. in fact round here you can fin some that do the whole cul-de-sac, or even on a ring with one service valve at both ends, so you turn one of only to find its back feed from the other end!! but i think you'll find the most suppliers will say that it is your resposability to get a seperate main put in!! they don't tlike doing to much!!
20-12-2011 #3UK Plumbersforums Trusted Advisor.
- Apr 2008
- South Shropshire
- 6,077
- 514
- Thanked 679 Times in 613 Posts
If the customer's open to having a water meter this should solve the problem.
21-12-2011 #4Plumbing Forum Contributor
- Apr 2011
- 60
- Thanked 6 Times in 6 Posts
It is not at all unusual for older properties to have one external stopcock for several properties. You could get her to ask her nieghbours if they know where their internal stopcocks are. Also in some there is an additional "internal" stopcock that is actually outside in the ground adjacent to where the pipe comes into the property, say outside the kitchen in the back garden.
22-12-2011 #5Moderator
- Nov 2007
- hythe hampshire
- 9,098
- 479
- Thanked 761 Times in 741 Posts
you after some free advertising there? try asking first mate.
Leaking Stop cock
By plumbingdazman in forum Plumbing ForumReplies: 3Last Post: 07-05-2010, 01:33 AM -
leaking stop cock
By GBZ in forum Plumbing ForumReplies: 11Last Post: 23-03-2010, 07:58 PM -
stop cock internal
By dave1 in forum Valves & TapsReplies: 3Last Post: 29-10-2009, 06:47 PM -
Outside Stop Cock(Tap?)
By smellynose in forum Valves & TapsReplies: 2Last Post: 04-09-2009, 02:19 PM -
Jammed outside stop-cock
By mark9724 in forum Valves & TapsReplies: 3Last Post: 28-05-2009, 05:35 PM
www.ourworker.com
