Old 25-02-2008   #1 (permalink)
whyme!
View whyme!'s Photo Album
Default speedfit fittings
I am having building work done at the moment. The person doing the plumbing is using speedfit connections for water and heating below floorboards, and connecting from old copper with a type of plastic pipe that connects via the speedfits. Is this normal these days, or should he be using copper below floors?
He has also put a connection(compression) joint below a block and beam ground floor.
None of this seems right to me.
whyme! is offline   Reply With Quote
Old 26-02-2008   #2 (permalink)
Matty A
View Matty A's Photo Album
Default Re: speedfit fittings
Im very new to plumbing and am only self taught so my advice is only from my own experience. Speed fit is as it says and it makes the job much quicker it is designed for heating aswell as domestic water i use both copper and speedfit it all depends on the job at hand. as long as he is using the pipe inserts which stiffen the ends of the plastic and also create a secondary seal then you should have no problems.
John Guest - The World Leader in Push-in Fittings, Pipe and Plastic Plumbing Systems
this should put your mind at ease.
Good luck..
Mat
Old 26-02-2008   #3 (permalink)
Lee
View Lee's Photo Album
Sometimes we have to mix and match as the exsisting plumbing and building can dictate how a job is done. Plastic is OK , I would always recommend pressure testing the system prior to filling just in case.
Lee is offline   Reply With Quote
Old 27-02-2008   #4 (permalink)
Seek-A-Leak
Posts: n/a
View Seek-A-Leak's Photo Album
Talking Re: speedfit fittings
Hi, speedfit is no problem for what you are wary about, its the inthing for most new constructions having these pipes and connectors but you should have around a couple of metres of copper pipe from the main source of heat before the plastic pipes are started. on a different note i am currently in talks with john guest and a couple of other companies regarding a new range of products i have patented recently, which are like speedfit but come in two halves to be clamped around a straight, Y ,T or Elbow/Bend in the event of a leak or break in the pipe as a emergency or permanent repair, so it eliminates the need to drain or shut down the system for not only the pro but also the ordinary joe public. quick, easy and cost effective. i have just come off of an american plumbing forum and they being pro's and seeing business loss deleted my idea after a while to which i only wanted feedback and views. i know there are clamps, speedfits and bulky repair kits but this is niche. Let me know your view.
Regards
Paul Stoner
Old 08-03-2008   #5 (permalink)
fizzput
View fizzput's Photo Album
You should make sure you can access any compression fittings under the floors once everything is made good...think that's in the building regs (off to read books....)
fizzput is offline   Reply With Quote
Finding x, (w and z) zones for fittings pudzamoisey Plumbing Forum 3 4 Weeks Ago 06:18 PM
bathroom fittings claystiles Plumbing Forum 2 01-09-2008 10:37 PM
bartol coppertone fittings sunshineplumber Plumbing Forum 1 19-08-2008 08:02 PM
