Plumbing & Plumbers Forum - Low flow rate
Low flow rate
Discuss Low flow rate in the Plumbing Forum at Plumbers Forums; Hi guys can I have some advice pls. I am renovating a house have 3 toilets 2 bathrooms inc 2 showers 1 bath. I would like a combi boiler/mega flow ...
    10
    Default Low flow rate
    I am renovating a house have 3 toilets 2 bathrooms inc 2 showers 1 bath. I would like a combi boiler/mega flow set up, but I only have 2 bars pressure, 1.5 bar working pressure, and the flow rate is 13 lpm. we are 50m from the street main, is the any device or system that will give me a good enough flow rate for a good shower, and good bath fill up.(Not neccesarily at the same time). We have a new 25mm supply from the road.
    SimonJohns's Avatar
    Bridgend, Wales
    3,609
    Default
    A break tank with booster set will give you amazing flow rates. But it will cost alot
  3. "nothing is impossible"
    steveb's Avatar
    Nov 2007
    hythe hampshire
    8,983
    Default Re: Low flow rate
    are your stopcocks fully open? main one in pavement or wherever and one inside house
    SimonJohns's Avatar
    Bridgend, Wales
    3,609
    Default
    Sorry. Should of said if you go for the boosted option. Go for the twin pump. For when you have a failure. Or have a bypass cut in
    10
    Ok gentleman, thank you, whilst I'm not loaded, price isn't the issue, I only want to do it once, so I want to get it right 1st time. I will also check the stopcocks before I do anything cos thats a proper cheap solution.
    thanx again
    east london
    6,666
    id be going for a system boiler and conventional hot water system if you have room for a tank
    you could then just pump the showers , if you have the room and can get tanks high enough you might not even need pumps a low preasure shower mixer will give a decent shower if you get 6ft of head
    there is a lot to be said for keeping it simple we dont get many queries on here regarding conventional systems as its tried and tested (low)technology
    remember youll be paying to maintain it once its finished
    sounds like youve got a fair sized job there where are you ??
    10
    I'm in Stopsley, nr Luton. It was a small 3 bed detached cottage, and we've extended round 3 sides. it will be a nice size, but it's not massive. We've stripped it right back to a shell, and we then had a blank canvas. So nothing is ruled out.
  1. Flow rate on boilers ?
    By philipcooepr in forum Central Heating Forum
    Last Post: 27-07-2011, 11:48 AM
  2. Flow rate
    By billybongo in forum Plumbing Forum
    Last Post: 01-05-2011, 07:06 PM
  3. Combi Flow Rate
    By mo7 in forum Central Heating Forum
    Last Post: 06-01-2011, 01:02 AM
  4. M3/Hr gas flow rate
    By pauls in forum Gas Safe Register Forum - Public Forum
    Last Post: 08-03-2010, 08:19 AM
  5. Pushfit flow rate
    By 21stcenturyelec in forum Fittings & Pipes
    Last Post: 23-06-2009, 02:28 PM
