Results 1 to 11 of 11
Plumbing & Plumbers Forum - Washing Machine Plumbing Problem
Discuss Washing Machine Plumbing Problem in the Plumbing Forum at Plumbers Forums; Hi All, Firstly, I'm not a plumber just a general d.i.yer Problem: The washing machine valve connected to the mains water is locked in the open position. Tried everything and ...
    Aug 2010
    Default Washing Machine Plumbing Problem
    Hi All,
    Problem: The washing machine valve connected to the mains water is locked in the open position. Tried everything and no good. There is no way of getting at the valve without ripping out the work top and probably pulling a few tiles off the wall at the same time!
    My washing machine has developed a fault and is going in for repair under warranty. So I need to temporarily disconnect the washing machine and thus flood the place (unless I turn of the at the mains).
    So I was wondering: Is there a temporary way of capping off the valve, or better still, a way of capping off the washing machine hose ? (at the machine end), while I wait for the machine to be repaired (3/4 days).
    Thanks in advance
    Resolute's Avatar
    Horsham, West Sussex.
    2,045
    Default
    You should be able to get a blank plate to screw onto the washing machine valve. Surprised that you cant undo the existing one and replace though - got any pics?
  3. GSR? Want gas safety or boiler repair advice? We will check out that you're genuine via the gas safe website, so please dont be offended when we ask for your details. DIYers, odd job people and have a go heroes need not apply.
  4. The Following User Says Thank You to Resolute For This Useful Post:
    Stealth (25-09-2011)
  5. #3
    Aug 2010
    Default Re: Washing Machine Plumbing Problem
    Quote Originally Posted by Resolute View Post
    I would like to replace but as I said the space is inaccessible. When I replace the worktop and tiles I'll certainly replace, but at the moment it's a no-goer.
    When you say you should be able to get a blank, how sure are you? I've searched the Screwfix website and can't find anything. Can you point me in the right direction.
  6. #4
    Resolute's Avatar
    2,045
    Default
    You need a 3/4" blanking cap, any plumbers merchant should be able to supply one.
  7. The Following User Says Thank You to Resolute For This Useful Post:
  8. #5
    Oct 2009
    758
    how about a self tapping valve, if you can access a small piece of pipe that is?
  9. The Following User Says Thank You to nysk2008 For This Useful Post:
    Stealth (28-09-2011)
  10. #6
    dontknowitall's Avatar
    Apr 2008
    South Shropshire
    6,039
    Can you get to the pipe earlier in the pipe run? If so, you could fit an isolation valve.
  11. The Following User Says Thank You to dontknowitall For This Useful Post:
  12. #7
    Mar 2011
    241
    Or call a plumber.
  13. #8
    Aug 2010
    Thanks for all the useful replies. Managed to get a 3/4" blanking cap from B&Q for a couple of quid - 2 mins and job done.
  14. #9
    AWheating's Avatar
    WestMidlands
    5,777
    why not put a washing machine valve on the other end of the hose as a temp cap end?
    btw im commercial,
    NOT.
  15. #10
    Resolute's Avatar
    2,045
    Default
    That's thinking out the box!
  16. #11
    Apr 2009
    2,686
    how did you cap the valve if you can't get to the valve? a cap won't be much good on the end of a hose unless it's got a valve on it.
    *brilliant signature*
  1. no plumbing/waste pipe for modern washing machine help!!
    By kirstylee in forum Plumbing Forum
    Last Post: 06-07-2011, 07:20 PM
  2. About plumbing in a washing machine?
    By Smcart5 in forum Plumbing Forum
    Last Post: 20-04-2008, 09:28 PM
washing machine plumbing problems
problems plumbing my washing machine
site:ukplumbersforums.co.uk plumbing washing machine no valveproblems with washing machine plumbingplumbing problems with washing machinewashing machine without plumbingplumbingmywashingmachine
