Results 1 to 9 of 9
Plumbing & Plumbers Forum - circlip on pillar taps?
Discuss circlip on pillar taps? in the Plumbing Forum at Plumbers Forums; Could someone please tell me what the circlip on a pillar tap does. Cheers...
    Sep 2011
    Default circlip on pillar taps?
    May 2009
    7,302
    Default Re: circlip on pillar taps?
    it stops the tap top inner's from screwing down instead of the bottom inners screwing up,without it the tap will not work correctly
    imho
    Plumbstar Tom's Avatar
    Jul 2009
    Staffordshire
    2,561
    yeah it stops the internals of the valve moving so the actual washer moves
    Why you ask?
    Regards
    Tom
    Sep 2011
    Quote Originally Posted by Plumbstar Tom View Post
    Why you ask?
    Thanks guys.
    I have just cleaned up the tap, and put a new o-ring in it, but as I was finishing the circlip fell out!!! The screw on top of the tap has threaded, and so I can't remove the tap head. This means that the cover that goes over the nut that connects the tap spindle to the tap body doesn't come off fully, and so I can't get the circlip back in place. (slightly complicated to explain!! do you know what I mean??)
    Any ideas??
    Sep 2011
    Jul 2009
    Staffordshire
    2,561
    is that tap a branded tap or is it a budget B and Q china jobby?
    If its branded, best bet is to get a new tap valve off the manufacturer
    If its Band Q then its time for a new tap me thinks
    Regards
    Tom
    dontknowitall's Avatar
    Apr 2008
    South Shropshire
    6,077
    Quote Originally Posted by anthony44 View Post
    Many thanks for asking that one - I've often wondered myself!
    Mind you, I've been careful to ensure I've replaced it properly as I suspected there was a good reason for it!!
    east london
    6,744
    new tap simples
    Apr 2009
    2,688
    New tap valves - even easier - and nice fresh new tap workings to boot. Take old valve with you to merchant with the handles and covers, hand it to the oldest wisest owl there, grunt in his general direction and watch as he wafts off down the corridors of spells and fairies and returns with a nugget of purest gold.
    *brilliant signature*
  1. Bath taps to Basin taps - alter flow
    By ejgray in forum Valves & Taps
    Last Post: 28-05-2011, 06:44 PM
  2. Armitage tap circlip
    By pramsrmike in forum Plumbing Forum
    Last Post: 02-05-2011, 11:41 PM
  3. Atlanta pillar taps
    By Ken Pickering in forum Plumbing Forum
    Last Post: 17-03-2011, 07:02 PM
  4. Bath Taps (pillar)
    By Leoki in forum Valves & Taps
    Last Post: 10-01-2011, 11:42 AM
tap circlips
circlips for taps
tap circlip
circlips for taps supplierscirclip tapcirclip pillartap circlip what is the function
