Plumbing & Plumbers Forum - soil vent/pipe
soil vent/pipe
Discuss soil vent/pipe at UK Plumbers Forums; Hello, I recently moved in a bungalow and noticed there is no soil vent/pipe (I guess the waste goes straight to the drain/sewer?). I was told such pipe is usually ...
    Aug 2011
    Default soil vent/pipe
    Hello,
    I recently moved in a bungalow and noticed there is no soil vent/pipe (I guess the waste goes straight to the drain/sewer?). I was told such pipe is usually found if there's a toilet on a floor above ground, which is not the case for me as the loft isn't converted. Is this correct? I want to fit another bathroom on the ground floor and was told by another person I will need a soil/vent pipe. Can you tell if that's right? Thanks
    Plumbers Arms member secret squirrel's Avatar
    Feb 2009
    Essex
    2,531
    Default Re: soil vent/pipe
    You need to look at the back of the existing toilet and follow where the waste has to go, you will have a soil pipe but it may be very small.
    You have a couple of options to install a new bathroom, you can have a saniflo but better if you can run a soil pipe get a couple of pics and post them up give us a better chance.
    Plumbers Arms member missplumb's Avatar
    Middlesbrough
    637
    if it is a bungalow then its not unusual for the toilet to go straignt below ground and into the drain, because the length of run from the toilet to the main drain will be quite short there mignt not be a need for a stack and there will be a vent stack at the head of the main drain run. But if you want to put another bathroom in then it would be good practice to have it done correctly and have a soil stack fitted to the drains.
    Unregistered
    Hi my property is suffering a terrible stink! I investigation there us no stench pipe..The bathroom is downstairs and the soil pipe leads directly to main drain. .manhole just outside bathroom. What can I do as the pong can be really awful!
    Forum Thug
    croppie's Avatar
    23,722
    Please register with us and start a new thread to receive an answer to your question.
    Croppie
    (By the way, I'm commercial!)
  1. Cannot find soil vent pipe in new house
    By benws1 in forum Plumbing Forum
    Last Post: 10-07-2013, 09:35 AM
  2. Soil pipe to vent or not to vent. Or to AA, or nothing
    By RayPlumb in forum Plumbing Forum
    Last Post: 02-04-2012, 09:59 AM
  3. soil and vent regs
    By plumber89 in forum Fittings & Pipes
    Last Post: 12-01-2012, 07:29 PM
  4. Soil vent pipe inside flat
    By Cristina in forum Fittings & Pipes
    Last Post: 04-08-2011, 08:04 PM
  5. help running soil and vent pipe to new bathroom
    By ajsoad in forum Plumbing Forum
    Last Post: 30-05-2011, 02:48 PM
  6. Soil Pipe / Vent / Durgo
    By itcwinner in forum Plumbing Forum
    Last Post: 30-11-2010, 12:30 AM
  7. Soil Pipe and vent move to outside?
    By 5035 in forum Plumbing Forum
    Last Post: 26-09-2010, 10:10 PM
  8. soil and vent pipes
    By mattsimmons in forum Plumbing Forum
    Last Post: 20-06-2010, 09:36 PM
  9. soil/vent pipe Advice
    By UKPITA in forum Plumbing Forum
    Last Post: 11-03-2010, 12:33 AM
  10. New bath?
    By con5933 in forum Sanitary Ware
    Last Post: 21-05-2008, 08:01 PM
do i need a soil vent pipe in a bungalow
drain vents in bungalow
saniflo in bungalow without soil stack
where will the soil pipe be on a bungalow
bungalow no soil stack
